Show me or tell me about your inline pump mounting!
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I am looking for pics or descriptions of mounting locations. Also, if you installed it in the rear how did you hook up the lines? Maybe some of the ATI guys can chime in, as I thought the kits came with inline pumps. Does it matter if the pump is before the filter? I know the stock pump is but maybe the inlines are more sensitive? I use my pump as a booster. Thanks
Get or make a bracket
drill 3 holes in the drivers side rear seat hump
attatch bracket
cut steel line and flare
attatch inlet/outlet hoses
wire up relay
have a nice day
attatch bracket
wire up relay
have a nice day
you use a single flare and then put the fuel injection hose over it.....if you dont flare it, it could leak gas
also, you dont have to drill 3 holes. My ati bracket had 3 holes, so i just said it cuz that is what i had to do
Originally posted by GofasterFirebird
Yeah and the inline pump will be also subjected to the sock. What is your point?
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
No big trick
It is my understanding that the filter is more intended to protect the fuel injectors which really, really don't like dirt, rather than the fuel pump. The sock, a 40 micron "filter", is just in place to keep the 5 micron fuel filter from clogging. The only problem with placing the aftermarket fuel pump before the filter is that, under high pressure, your aftermarket pump will be much more likely to cause your fuel filter to burst due to it's ability to pump to higher pressures, and the stock filters' limited volume potential. My vote is after the filter to be on the safe side.
ambainb
04-25-2016 09:21 PM
toronto formula
11-10-2015 06:17 AM
