Budget Rebuild...Vortec Heads with what cam?
1 Post
Car: 1988 IROC-Z
Transmission: WC T5
Hey guys,
I am planning to rebuild my engine, but must do it within the confines of a pretty tight budget. I have decided to go with the Vortec heads and SDPC manifold. My question concerns cam selection and computer compatability. I don't want to get into having a custom prom burned. What cams (hydraulic flat tappet) are out there that will be compatable with the stock prom ('88 350 TPI) and offer a performance increase over the stock cam? Thanks for any info.
Car: Check The Sig
hey after 87... all cams in both the 305 and 350 are hyd. roller cams.... thats gunna jump ur price up right away... i suggest the lt4 cam.... but ur gunna look for 1.6 rockers... if u dont wana go lt4... try lt1 or something of that nature
1 Post
Car: 1988 IROC-Z
Transmission: WC T5
I realize that after 87 the cams are roller cams, but I am going to go with a flat tappet hydraulic. I know that I won't be able to get a flat tappet cam that is as aggressive as a roller cam, but because I am retaining the stock prom that won't be an issue. Are the LT4 and LT1 cam specs compatable with the factory prom in my 88 IROC?
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
You can also use the ZZ-4 cam and it will work fine with the stock prom. A ZZ-4 cam can be purchased for $100.00 and you can reuse your roller lifters. Try and use a roller cam.
1 Post
Car: 1986 Z28
Engine: 355
Transmission: th400
if your gonna use a late model block with the flat tappet lifters. A good cam for it would be the comp XE 262H-14. grind number 12-262-4.
it's a grind desgined for tuned port, will work well with those heads, and be computer friendly. Will need a custom type chip, but overal shouldn't be overly difficult to tune.
