How much vacuum do you have with ZZ4 cam?
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
I'm wondering if my vacuum is up to par with others running a ZZ4/ZZ3 cam?
I'm getting a steady 14 inches at 700 rpm idle, is that about right with this cam?
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I got 14-ish ... right now I got a darn vacuum leak so the gauge wiggles between 13.5 and 14.25 (or there abouts). I think I have had my TPI apart too many times ... need new gaskets.
In diag mode (1000 RPM), it is solid at 16 or 17.
Mark.
Mark.
Well, I can't find any vacuum leaks of any kind, used all new gaskets the last time it was apart, the only vac line I have thats hooked up that is not ported is the PVC on the driver side, the others are either ported or capped off.
It runs darn good now that I started burning chips for it, maybe I'll experiment with the spark adv at idle as I do have a funny/odd popping sound at the tailpipe when listening thru a stethescope thats unlike any other of my cars.
86CamaroDan
09-29-2015 10:08 PM
