where can I get these o-rings
Old 06-26-2002 | 01:03 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
The o-rings that go between the crossovers on the fuel rails. I accidentally boogered up my old ones. The parts stores I've checked say they can't get them, and the dealership wants to sell me an entire kit for $22!! I'm not real excited about spending $22 just to get ahold of two o-rings. Ideas?
Old 06-26-2002 | 01:13 PM
tpi_roc's Avatar
I'm not sure i know the ones you're talking about, but by chance would they be the same size as an injector O-ring?
Old 06-26-2002 | 03:11 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Between the o-ring board at Aubichon Hardware and an o-ring kit in my garage, I got everything I needed. The aubichon rack should have everything you need tho. Just keep in mind that one of the little ones that go on the little rod that goes into the base of the FPR are a different size than the rest.
Old 06-27-2002 | 07:20 AM
ZZsmpch's Avatar
Make sure you don't get just any old plain rubber O rings either. The viton ones are impervious to fuel, but the other ones will break down and leak.
Old 06-27-2002 | 08:57 AM
Brian'sIROC's Avatar
I broke down and spent the twenty bucks on mine. At least you know that you have the right stuff with the GM kit, and if it's already apart, why not do them all. And don't buy hardware store o-rings, they are for plumbing(water) not gasoline. Get neoprene rubber o-rings.
Oh yeah, ASM (Arizona speed and marine) sells the kit too. Probably more than GM charges though.
gixxer92
05-18-2017 11:20 AM
BOOT77
09-16-2015 08:37 PM
BOOT77
09-05-2015 03:55 PM
bamaboy0323
09-03-2015 06:07 AM
RED85TPI
Brakes
08-31-2015 10:29 AM
Quick Reply: where can I get these o-rings
