TPI swap - is an 88 or 89 system better?
Old 06-23-2002 | 09:08 AM
PerthZ28's Avatar
I have the choice of 2 TPI systems for my swap - an 88 and an 89. Which will give me the better result?
Are there better PROMs available for 1 or the other [I will burn my own chips eventually]? It's going on a 350.
Am I better-off without the cold start injector or is there no real difference?
I already have the 88 wiring harness and ECM with an ADS chip in it but using it with the 89 system should not be any drama?
Old 06-23-2002 | 09:34 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
everybody run's the 89, just like you mentioned no CSI. since the popular ARAP bin is an 89 and it has no need for CSI. it would the best choice. looks a little cleaner w/o the CSI.
there would be no drama since the only true diffrence is the CSI. just tuck it away and be done with it.
Old 06-23-2002 | 11:33 PM
Jza's Avatar
Jza
I like the 88 fuel rails on an 89 TPI. The reason is you can use the extra port normally for the CSI to connect a fuel pressure gauge rather than tying up your schraeder valve.
Old 06-24-2002 | 01:46 AM
PerthZ28's Avatar
Which system had the better injectors or is there little difference?
Old 06-24-2002 | 12:38 PM
89Irocz23's Avatar
I dont think there is a difference, but if there was it would be 89
Fast355
12-02-2016 06:33 PM
Caspar
06-19-2016 11:19 PM
sreZ28
08-14-2015 07:48 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: TPI swap - is an 88 or 89 system better?
