hyper tech......how is it
Old 06-22-2002 | 01:05 AM
Transamws686's Avatar
Car: 1981 Trans am
Engine: 400
Transmission: TH350
Axle/Gears: 3:08 =(
hey guys its me again with another question, here we go. i am thinking about buying a hyper tech chip and whaty i was told was that i nedded a stage 2 thermo master chip. * this was told to me by the people at hypertech.) this i was told will help me blah blah blah, what i want to kno was your opinions on this. thnx again
Old 06-22-2002 | 09:05 AM
SMOKEN's Avatar
just berry the car i got the same car with 39 000 kilometeres i changed the gears to 3.42 and took off the cat with a hypertech chip and the car is still a 16.00 second car don't waste your money on these crappy tpi
Old 06-22-2002 | 10:26 AM
Guest
Guest
Posts: n/a
I have one of those. Dont waste your cash. The only change is the WOT timing curve, you could make that change close to theirs by turning the distributor a little.
Do headers and cam before you do that.
Old 06-24-2002 | 01:02 AM
89Irocz23's Avatar
I would recommend getting into custom prom tuning. Also if you can find someone to burn a chip for you. Dotn waste your money on hypercrack stuff.
Old 06-24-2002 | 11:10 PM
Car: 1981 Trans am
Engine: 400
Transmission: TH350
Axle/Gears: 3:08 =(
so u know anybody who does custom burning and what should i get it programed for:hail:
Old 06-25-2002 | 09:48 AM
tpi_roc's Avatar
Lots of people do custom burning, and you should get it programmed for your car.
Either do your own or go to a company that will tune specific to your vehicle, ed write etc..
Old 06-25-2002 | 10:14 AM
turtle's Avatar
i agree with all the above, i have a thermomaster and it does more harm then good for me. for slightly more $$$ you can sart burning your own chips.
Old 06-25-2002 | 10:51 AM
tpi_roc's Avatar
$160 is all the money I think i've spent on prom burning
and its an investment with continued returns unlike buying one hypertech or even one fastchip etc.
Old 06-25-2002 | 12:22 PM
ngafp's Avatar
Car: 1992 Z28
Transmission: 700 R4
hypersh**
really didn't make much of a difference except for WOT wish i had gone with custom chip first don't make the same mistake.
Old 06-25-2002 | 01:50 PM
SLOW91TA305's Avatar
prom burning? how does someone get into that?
what hardware/software do I have to buy? what brand should I get? or better yet, where do you buy this at?
maybe someone can point us in the right direction
thanks
Old 06-25-2002 | 02:56 PM
tpi_roc's Avatar
There is an entire board devoted to it, in that board you'll see big flashing lights pointing you to the tech article on it, the tech article has 100% of all the information you need to burn your first prom, if you still have questions then the "DIY PROM" board will be more than happy to answer.
Old 06-25-2002 | 04:14 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
I wouldnt recommend it either... was a big waste of money on my part. Like the others said, if you have the time/money, get into prom burning.
Crappy TPI huh? Uhm, if your TPI car cant break 16's with those mods, theres probably a few problems:
1. You cant tune it.
2. You cant drive it.
3. Both 1 & 2.
Old 06-25-2002 | 04:48 PM
BD3's Avatar
BD3
My IROC turns better times w/ Hypertech Stage II chip than the $400 "custom chip" from Performance Resource.
BD3
Old 06-25-2002 | 11:12 PM
Car: 1981 Trans am
Engine: 400
Transmission: TH350
Axle/Gears: 3:08 =(
hey guys i looked but where is the tech article and the board dedicated to the programing, i would love to learn to do this my sdelf.
Old 06-26-2002 | 12:31 AM
Kandied91z's Avatar
i had to spend over 200 for the chip as well as purchase the fan switch and a thermostat and i didn't notice any gains at all with the stock engine setup and even after modifying the intake and exhaust..........
i eventually pulled it and pawned it off to some kid for gas money.
biggest waste of money ever.
Old 06-26-2002 | 04:09 AM
ZZsmpch's Avatar
Look at the top of the TPI board for the thread titled "Sticky: TPS enhancer with a performance prom " Then go to the DIY prom board and look at the first thread titled Announcement: Make sure you read Trax's Introduction to Prom Burning article! That should just about cover it.
jaridjohn
10-05-2015 07:01 AM
pauls
Aftermarket Product Review
01-04-2002 11:06 PM
pauls
12-25-2001 01:28 AM
F-Messenger
11-10-2001 01:38 AM
F-Messenger
10-23-2001 07:41 PM
Quick Reply: hyper tech......how is it
