car dies when put in gear (sometimes)
Old 06-20-2002 | 07:20 PM
mckenzie's Avatar
Hello all. i have a 86 iroc with a 305tpi and auto trans. sometimes when i put the car in gear (from park to drive or rev.), the engine dies...mostly when the car is cold. and when i come to a stop, it seems like its going to die....acts like iac motor is slow to respond. put new iac motor in appx 1000 miles ago, got updated prom from gm (thought that would fix my problem) last year. if anybody has had this problem, or knows of anything i can try, please let me know. thanks, tom
Old 06-20-2002 | 11:41 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
What is the car idling at in Park? Does it die everytime? If not, what does it idle at in drive? Are you getting a check engine light? If you're getting a check engine light, it's more than likely your MAF sensor of MAF relay. If not, i'd just try turning the idle up.....but I can't really give you a straight answer till I get a little more info....
Old 06-21-2002 | 09:32 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Check your minimium idle speed, it should be set at 500 RPM in drive. The minimium idle speed on some TPI cars was to low and GM sent out a service bulliton requesting dealers to check and make sure the minimium idle speed was set to 500 RPM in drive.
Old 06-23-2002 | 04:16 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Hey everyone. I'm new to the forum, so Hello to everyone. Is there any possible way that your TCC is sticking? If so this may also be causing your stall. Just a thought?
Old 06-23-2002 | 04:45 PM
Arawn's Avatar
A few things helped me with the exact problem on my 86 TA. But the fuel filter was the biggest thing that helped. Vacum lines were also a big help. I replaced like 20 feet of bad hose a few months back
Old 06-23-2002 | 11:46 PM
Jza's Avatar
Jza
Scan it and see if the Park/Neutral flag goes on and off when you move the gear selector. If your park/neutral switch doesn't work, the ECM won't know to kick up the idle to prevent a stall because it doesn't know it when you go into gear.
At least that's what it was in my case.
Old 06-26-2003 | 08:46 AM
abcx09t's Avatar
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
What do you mean by "scan it"? Do you mean check the codes?
mizz0313
08-12-2015 06:45 AM
dhonda200
08-11-2015 11:50 PM
killer777
08-08-2015 02:47 PM
Quick Reply: car dies when put in gear (sometimes)
