what cam is better for the 86 305 tpi
hi guys i just bought a book it is called chevy tpi fuel injection swapper's giude and i found something about the cams for the 305 now can someone tell me wich one is the best for me
comp hydraulic 212 /212 444/444 112
comp hydraulic 212/218 444/444 114
summit 204/214 420/442 112
now the only mods on the car is exhaust and gears i got the 3.42 in there
thanks
thanks
I installed the Summit Cam in my 86 Z28 with the TPI and was fairly happy with the performance. There is no doubt you will notice it. I have no performance numbers for you. The idle was slightly rougher, but not something In my opinion to shy you away. It was very streetable, and performed even better when I added the TES system from Edelbrock and did some mild porting while the intake and runners were off. I installed the cam in my camaro about 9 years ago when Summit first offered the cam....and its still in there. Hope you enjoy the cam if you buy it, and don't forget to replace the valve springs while your there, especially if you have any mileage on your 305.(not a bad idea to replace those lousy oils seals on the valve stems with the premium ones, and make that morning blue smoke go away!!)
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Originally posted by 89Irocz23
ask zepher what he had in his. He had tpi, but I dont think his block was a roller motor, but i believe he had a decent cam in his 305.
Just make sure that you don't go with too much cam. Bigger doesn't mean better if you don't have the motor to support it.
i have the comp cam 212/212 444/444 112. nice idle, and good vacuum. i'm happy with it. i couldn't tell you the performance gains, because i bought the car with a bad motor and just rebuilt it. best of luck, tom
p.s. please let us know what cam you choose.
Sanjay
08-12-2015 03:41 PM
