.420/.442?
Car: 86 iroc
Engine: 355 400hp
Transmission: 700r4 race built
Axle/Gears: 4.10 posi
.420/.442?
I have an 86' iroc 305tpi getting a cam kit with a lift of.420in intake and .442in/exhuast a duration of 268 intake and 278 exhuast, and was wondering if anyone knows if this is a good cam for my motor. i have a ported plennum,runners and intake. Have headers and dual exhuast.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
replacing the peanut cam eh?
Sounds like your getting the Summit/Crane Blazer cam. I ordered the Crane Powermax 2030 which has about the same specs. I had to return parts to my local speed shop and the 2030 + CRANE FPR was a even swap.
Need to get it installed. Should be worth 30-35 hp alone, + another 10-15 from porting the base/plenum.
I would go a little more aggressive, I am running a compcam.
.495/.503 218/224 and I wish I had gone bigger than that. The stock heads will hande up to around.470, I would look at something around there.
nick
nick
i got that cam in my motor but i wish i would have gone with some thing a little bigger cuz that's that bearly bigger than stock lift on a 350 but it might turn out go on a 305 try maybe a little bigger.
i to want to change my cam 86 305 tpi ta now i was going to go with the summit tpi cam kit now you guys confuse me your saying i can go bigger if so how did your 305 run did you burn a chip for it what gears should i have ect. thanks
