What injectors do i need?
Car: '87 Camaro LT
Engine: 355 L98
I'm in the process of swapping to an LT1 intake and was going to use the 22# injectors i now have but i'm now having doubts about them being enough. Desktop dyno tells me i'll be making 360-380hp with a single plane intake, which i figure is closest to LT1.
Should I get 24# ones? Will 28# LS1 injectors fit?
EDIT: did some research, due to differences in fuel pressure, an injector that's 28# on an ls1 is only 24# on an lt1. so if i'm going to upgrade it'll be to lt1 24# injectors.
Car: Damn
Engine: This
Transmission: New Stuff
24# are fine for that power level, unless you are going for more down the road.
As for the LS1 injectors, they should be the newer multec design. I'm not sure what the differences are between those and ours. Something to check.
thejimsterz28
09-15-2015 04:37 PM
