base porting
Old 06-10-2002 | 08:13 PM
86FOURSPEED's Avatar
base porting
i have seen the article on porting the plenium but everyone says there are more benefits in porting the base but nowhere have i seen what is to be ported or how to do it
Old 06-10-2002 | 09:44 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
The idea is to siamese the runners of the base to gain high RPM flow and smooth out the torque curve. Here is a pic of mine:
Old 06-10-2002 | 10:39 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Go and ask this on the tech/general engine board and Vader with show you an artical he has on base porting/plenum porting. Or you could extensively search for it.
Old 06-10-2002 | 10:59 PM
spearson's Avatar
edited because I found my answer in another post.
Old 06-11-2002 | 09:21 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Re:
What are you guys using to port it with. I have an air dremel tool, but can't find any attachments that work worth a shi*. Any ideas? What do aluminum head porters use?? THX
Old 06-11-2002 | 09:51 AM
Morley's Avatar
Re: Re:
You could use and end mill, if you have a milling machine. Or you can use high speed rotary files in an air powered diegrinder. The air powered "dremel tool" is probably going to be too weak for a job of this size (takes several hours) and the bits for it have teeth that are too small and will clog up with the aluminium. You can get a good 90 degree angle die grinder from Harbor Freight or the like for around $20.
~M~
Old 06-11-2002 | 10:13 AM
tpi_roc's Avatar
A die grinder and 1 carbide burr is more than enough.
"Aluminum porters" use a longer bigger version of a dremel specifically made for porting.
www.ruffstuff.com
Old 06-11-2002 | 01:32 PM
Matt87GTA's Avatar
Use a pneumatic Die Grinder with a carbide grinding burr and be sure to use gear oil to lube the bit every few minutes while porting. The gear oil is awesome at keeping the bit cool and free of AL in the teeth. Read the tech article on siamesing the base on this site.
Old 06-11-2002 | 02:56 PM
Bort62's Avatar
Old 06-11-2002 | 02:58 PM
Bort62's Avatar
Die grinder and a Carbide Burr.
Old 06-11-2002 | 03:07 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Re:
Thanks guys. What I have is actually an air die grinder, not just a little dremel tool. Anyways, thanks for the quick responses. I wish I would've just used the mills at college last semester. I could've siamesed this thing in a half hour or so.
Mark_ZZ3
05-24-2018 01:02 PM
sammy52401
11-11-2015 07:20 PM
2012sergen11
10-13-2015 07:38 PM
Reid Fleming
10-10-2015 09:56 PM
ndndndnd
09-28-2015 08:00 AM
Quick Reply: base porting
