Runs like a DAWG
Old 06-10-2002 | 07:27 PM
IROCBlueZ28's Avatar
Runs like a DAWG
What woud cause your car to run like a dog? I have noticed that the headers glow a little bit red when I rev it in park. I rev it up to 5G in P and the headers seem to glow red, just enought to notice. It gets hot when sitting in traffic or at the bank, but it seems to run OK onthe freeway and in traffic, just underpowered? HELP!
Old 06-11-2002 | 01:17 AM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
You have alot of mods trying to get along. Did it ever run right? Or is it something that just came up.
I'd start with checking everything over, and see if it needs a tune up.
These cars will heat up when just sitting around in warmer weather, so if it is hot in WA right now that could be it.
TES headers use cheaper and thinner metal so they might glow more than others. I have them too, and have seen them glow also, but only when the car wasn't running right. Check your timing and fuel pressure. Usually when they glow an abnormal amount its the mixture being off or the timing is screwed.
That should get you started.
Old 06-11-2002 | 08:53 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If you headers are glowing you either have a lean mixture or your timing is retarded too much. I have the Edelbrock TES & they don't glow when it's tuned right.
Old 06-11-2002 | 08:54 AM
Ricktpi's Avatar
Originally posted by Ricktpi
If your headers are glowing you either have a lean mixture or your timing is retarded too much. I have the Edelbrock TES & they don't glow when it's tuned right.
Old 06-11-2002 | 10:17 AM
tpi_roc's Avatar
Timing
Old 06-11-2002 | 11:04 AM
I had my timing set at 6deg advanced. I pushed it up to 12 adv. I also increased my fuel psi from 43.5 to 50. NO change
Old 06-11-2002 | 11:47 AM
tpi_roc's Avatar
Is your EST plugged in?
Old 06-11-2002 | 12:15 PM
yup
Old 06-11-2002 | 12:48 PM
tpi_roc's Avatar
Any exhaust leaks?
Old 06-11-2002 | 12:53 PM
nope it sounds like$ feels like it runs perfect except the lack of power & it gets hot in standing traffic or sitting in line @ the bank???
Old 06-11-2002 | 12:54 PM
by the way...thank you for the effort of trying to help me fix my
? ? ? ? problem!
I appriciate all of the efforts!
Thank you all!
Azrael91966669
25
06-20-2017 04:04 AM
Fast355
12-02-2016 06:33 PM
perZ
08-21-2015 05:51 PM
ezobens
08-19-2015 10:29 PM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: Runs like a DAWG
