AIR or not?
Car: 1992 RS
Engine: 406 Stealth Ram
If yuo can find someone to inspect your car that will pass you even without AIR components, then by all means, get that AIR junk outa there! Ever changed your plugs with that crap installed? I did yesterday, and I can tell you right now, my new engine will NOT have any of that AIR crap on there
Do you have stainless steel air tubes that go into the exhaust
manifolds, there will be one tube in each exhaust port that come
up to a larger pipe with a rubber hose attatched to it.
Also there should be an air pump right below the AC compressor.
The car should have the AIR setup from the factory.
