Sportsman II's and comp cams XE268??
Car: 87 trans am, 93 full size blazer
Engine: 5.0, 5.7
Transmission: A4
I was just wondering if anyone has this combination with a TPI setup. I was considering this for my new motor. I am also debating getting an LT1 intake instead of my TPI, but does anyone have any experience with these products? Thanks in advance.
Man I wish you guys would include specs with the damn cams so we dont have to go look them up...
I have experience with the heads, and I have an LT1 intake that I've started to modify, but it will be going on a 385
Engine: 5.0, 5.7
Transmission: A4
thanks guys, sorry about the specs. here they are.
comp cams xe268
duration@.050
intake 224
exhaust 230
lift
intake .477
exhaust .480
LSA of 110*
comp cams xe268
duration@.050
intake 224
exhaust 230
lift
intake .477
exhaust .480
LSA of 110*
try one of these marine cams from Comp Cams:
XM262H grind / 12-236-3 part #
218/224 @ .050
.462/.477 @1.5 rockers
112* LSA
or
XM270H grind / 12-240-4 part #
226/236 @ .050
.480/.489 @ 1.5 rockers
112* LSA
I'm running the XM262H with 1.6 rockers(.492/.508) on Dart Iron Eagles, which are similar to the Sportsman II's.
218/224 @ .050
112* LSA
or
226/236 @ .050
112* LSA
Originally posted by tpi_roc
(so you dont get stranded in the middle of the ocean?)
You have sportsman II's??
These heads have 200cc intake runners basically throwing low end to the wind, so why not maximize where they do make power? That means duration, and lift, the LSA would be nice to run at 110 but thats just a bit to much for a '165/ '730 ecm to deal with.
I say get a cam with more lift, your heads can take it, so dish it to them
