Bad IAC valve?
Bad IAC valve?
Hi. I have 350tpi from 87 T/A on my 70 Camaro. Now, last couple weeks I have had problems with the idle speed. One day the idle speed is fine all the time. But then on the next day, I donīt have idle speed at all. Car will stall everytime when I raise my foot on the gas pedal. Should I just replase the IAC Valve or check out somethin else first?
Mika
Mika
The check engine light doesnīt come on when the engine dies. I havenīt check the codes. And I did disconnect the battery today, cause I did some welding job to fix a dent. The car died all the time this morning when I went to the work, but when I left from work, it worked great. And now I came back home from garage, it worked fine. Next time it dies, I will check out the codes immediately. I havenīt checked out the redings from the TPS or coolant temp sensor. Do I need scanner or computer to do that?
