help (injector size and will they fit?)
Hi,
I've got an '89 5.7 and I have a set of injectors that I've found out to be for an 87-88 Y/F-Body.
Question is, are these injectors I have 24 lb/hr?
Part number: 17111961
They show to be for a 5.7 87-88 and they're ACs.
I've also got an LT1 and the connector would fit on my LT1, so I was also wondering what other years will this work on?
Thanks!
Thanks!
For the most part injectors are injectors
Any Y/F body injector from 85-92 will work, and LT1 injectors (93-97) work, and so do ford SVO injectors.
They're all compatible
Thanks a lot guys, you have been very helpful.
Any other good guides you could suggest besides:
http://www.fuelinjection.com/portinj.html
http://iroc.fbody.com/injectors.html
Thanks again! :hail:
toronto formula
11-10-2015 06:17 AM
knight72
08-10-2015 09:32 PM
