LT1 adn EGR block update...
1 Post
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Since this was a hot topic a few weeks back, I thought I'd mention that since blocking the holes off on the heads, I've noticed a significant decrease in blue smoke when I start up in the morning. My guesstimate is that the open EGR ports were pressurizing the block causing some oil blow-by. Can anyone back this up?
Well did you previously notice the blue smoke under driving? Load? Idle?
At Idle the EGR shouldn't have been open unless it was stuck so thats some direction...
But I can't see there being any/enough pressure to cause blow by....
Done a leak down?
(If it was pressurizing the block that would only make it harder for oil to make it up into the combustion chamber due to the positive force)
Done a leak down?
1 Post
There was a lot of blue smoke on start up. Nearly nothing now. The way I've always understood it, the PCV puts a vacuum on the crankcase to pull fumes out and to help with oil control. By pressurizing the block, you'll push oil out all the seams. Namely the rings and valve guides. I did recently do a work over of the engine, but I left the heads alone.
And Its not "pressure" pushing oil out the seems, but gravity as far as the valve guides/seals go, and there's oil on cylinder walls from the crank splashing around in the pan, when your piston pulls down at say 40 times a second naturally its not going to be able to scrape EVERY bit of oil off the walls and some gets burned.
"start up" smoke is usually due to valve seals since looking from a gravity perspective it has the opertunity to leak down open intake/exhaust valves.
theres not really any route for oil to come UP passed the rings. Without a running engine.
Hope this helps (and hope I'm right)
Dont quote me
1 Post
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I was lucky enough when I did my prototype even though I didn't notice the gap in the intake flange. I have Trick flow G2 heads and the EGR port in the head is a very small 1/2" round hole, the LT1 intake more then covers that small hole so I never paid it much attention.
Still, be assured I am working on a simple way to fix the problem on future intakes.
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I welded a small piece of alum. angle plates to each side. I am running GM heads so this is the only reliable solution. You just have to use a square to make sure they are perpendicular with the rest of the flange.
I bought a roll of alum. wire and a 2' bottle of argon for my welder (approx. $40). You have to keep the wire very straight to keep the wire flowing correctly. It is just a generic mig shop welder. Or just make the pieces and have a local show weld it.
I also added weld to the top part up by the valve covers for that port and the water ports to make sure there was a good seal there. Without doing this, the gasket is just barely covered. This is just added insurance.
J
J
New2Chevy
09-28-2015 12:35 AM
