Holley Stealth ram READ PLZ!!!!
1 Post
Car: 1991 Camaro z28
Engine: 350 Tpi
Transmission: 700r4 Auto
I know this subject has been beat to death (and ive read ALL the other posts about it), but what all would i need to install it and how much will this cost me when its all said and done....final cost is what i mean. Also has anyone clarified the hood clearance problems?? BTW i have a 1991 z28. I'm interested in this stealth ram, but im kinda new to cars and im just lookin for some good advice and info about this..thanks alot guys
Car: 1987 Z28 Convertible
Transmission: 5-speed
Welcome to thirdgen.org where you will find answers to ALL your questions!! Now, check out all the links below to find all your answers:
https://www.thirdgen.org/techbb2/sho...hreadid=101421
https://www.thirdgen.org/techbb2/sho...hreadid=100760
https://www.thirdgen.org/techbb2/sho...hreadid=102160
https://www.thirdgen.org/techbb2/sho...hreadid=100525
Now be nice, hes new j/k
Im looking into it to. there is a lot of info around the boards, in diff. spots Heres some of it all in one spot.
Clearance is close but not a problem, it was installed on a '92 camaro with 350.
You have a '91 Z, and as far as I know they were all TPI so all you will need is the Upper and Lower, and fuel rail kit. All that together comes to about $450.00
Part Number for the upper and lower together is HLY-7540 from summit, and also from summit the fuel rail kit part number is HLY-534-185, both are back ordered to ship some time in early-mid may
Hope that helps!
Hope that helps!
Hood clearence shouldn't be a problem. You are also going to need to adapt to the fuel lines. You will need new intake gaskets, coolent, tread sealer, rtv, thermostat, oil change stuff, trox bits, a good torque wrench, a good set of socket wrenches, and maybe a new upper radiator hose. Other than the intake set up, depending on what you have lying around the garage anywhere from $50 to $250.
Its been covered already, but the stealth ram fits without any mods in camaros. On the birds, it fits with some "adjustment" of the braces on the underside of the hood (get out your hammer). I've already recieved and installed my intake but I'm still waiting for the fuel rails.
1 Post
Engine: 350 Tpi
the total kit
On their website they have something about the whole kit..with a throttle body, commander 950, and all this other stuff OR u can just buy the fuel rails and the manifold....where is this kit?? or am i just seeing things
You can just buy the manifolds and fuel rail kit, check some of the other stealth ram topics they're listed, I dont' remember 'em off hand, just order 'em from summit.
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
The whole Commander 950 kit crap is like $2200 or something, that's not what you want...
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
Ok, if I would use Stealth Ram with 85 TPI on 400 sbc, would it work (with bigger injectors and a chip)? Could it feed the 400? I am sure I would have to change to speed density, and buy another ECM, but which ECM?
Or should I just use a Holley 750?
Nonni
Nonni
9192camaro
16
02-03-2019 12:21 AM
L98GTA87
08-11-2015 06:55 PM
