what KN for cold air
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
For an MAF TPI you can only get K&N replacement filters... the square ones that replace the paper ones you have now. You cannot get a cone that sits on the end of the throttle body because you don't have speed density.
I would suggest getting the K&N replacement filters (approx $25 x 2) and then running ram air pipes to the front of the car so the air is fed directly to the filter.
no..i cant make cold air with MAF
I am running a 90 angle out of my TB,,then about 2 foot 3" pipe with my MAF sensor in it...and then mounting a KN on the end...i want a 3" roudn and about 9" long
thanks
aj
just need to know the model number
thanks
aj
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
according to Jegs......
K&N Cone Filters
View larger image
K&N universal round tapered air filters feature a 3'' or 3-1/2'' ID centered mounting flange.
599-RE-0810 3" id, 4-5/8"- 6"x9"L $ 46.99
599-RE-0870 4'' id, 4-5/8'' - 6'' x 9''L $ 42.99
599-RU-3130 3-1/2" id, 3-1/2"- 4-5/8"x7"L $ 31.99
599-RU-3480 4-1/2'' id, 5''-5-7/8''x6''L $ 42.99
I believe you are looking for the first one.. cheers, Bob
K&N Cone Filters
View larger image
OK this is the website that u need....
http://www.knfilters.com/universal/universal.htm
just choose the type that you want from measurements you take and then you will be able to find out the p/n.
Car: 84 SVO
Transmission: WCT5
try www.jegs.com
Car: 1989 IROC-Z
New idea... maybe you should get one of these...
https://www.thirdgen.org/techbb2/sho...threadid=47901
That looks ideal for a Firebird.
Car: 84 SVO
Transmission: WCT5
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
