Hope I didn't just jinx myself.
It seems every time I SAY my car will be somewhere, or do something I invariably end up breaking it somehow!
But this time it seems my car is actually in decent running shape! It'll be nearly 6 years since the car was last there.
Pray for me.
Pray for me.
Re: Hope I didn't just jinx myself.
My engine bay is ugly. Not tidy at all. But the wires are kept from burning, and the hoses don't burn either. But its not pretty at all, I haven't had the time to cut/splice the wires and clean it up.
yes unless something terrible happens I'll be there in the IROC. For the street, the setup is dialed. It is neutral, stable over bumps, and the car tracks straight. The mount I made that attaches the pinion to the roll bar is a little too tight and makes noise through the cage some times, but thats a noise issue not a function issue. I'll fix it this winter when I drop the unit to change fluid. I do have my rear sway bar on it now too, but the car is so low and so stiffly sprung the street tires can't provide enough grip to really get it to roll over at all so the rear sway bar is essentially useless on the street. Once I get slicks on it and get it to an autox event or a track day, that will reveal the next weak spots in handling.
I will say, compared to my 91 Trans Am, it is very surprising how much more stable over bumps the IRS is even with as stiffly sprung as it is. If it wasn't so much work and fab, I'd put a Dana 36 IRS in my Trans Am with the softer springs front and rear. It really does settle the car down and make it very nice to drive, much like a newer car. I think that is what GM was doing with the Firefox prototype GTA that they installed a C4 IRS in. It was a test to see if they could use their existing IRS for the 4th gens when they were still indevelopment.
I'd probably end up getting it in there crooked. how'd you measure it all up so the rear assembly was true with the car?
dbrochard
10-03-2015 12:43 PM
