New emission laws coming??
My buddy was telling me that he's heard in 2013 the emission laws will be changing so that any car with OBDII will need to be tested, but anything before that will not need it. Something about not using a dyno just plugging into the OBDII port and a sniffer in the exhaust pipe. Has anyone else heard that yet?
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: New emission laws coming??
I heard Ohio was getting rid of emissions for everything but 96 and later cars, which was the year OBDII was on every car. OBDII starting being put on cars in 1994.
Either way as long as they don't change the historical plates year limit or collector plate qualifications I'll be fine. 2014, your coming soon, that or $5k of good parts for collector plates, which do look prettier than plain white background with black text (Dang Ohio being decades behind plate design).
-Take care
-Take care
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Looks like he's right, googled DriveClean OBD and got these hits:
http://www.ene.gov.on.ca/en/air/driv...NAL_REPORT.pdf
(This one pisses me off because an American company did this review/report. Not because I don't like Americans, don't jump the gun on me cause I don't have a problem with our friends south of the border - but because our gov't keeps on saying "keep jobs here, choose Canadian services/items first!" and they can't even do it themselves. Even some of our highway signs were done in the states, and we have our own sign shop!!!!)
And this one:
http://www.ontariocanada.com/registr...42&language=en
Keep in mind, this all says Proposed changes, nothing is final apparently.
And this one:
Ministry: Ministry of the Environment
Regulation Number(s):
Bill or Act: Environmental Protection Act
Summary of Proposal: The Ministry of the Environment proposes amendments to Ontario Regulation 361/98 (Motor Vehicles) made under the Environmental Protection Act. The amendments to the regulation would modernize the Drive Clean program, including the implementation of computer based emissions testing for light duty vehicles.
The proposed amendments would prescribe new On-Board Diagnostic (OBD) emissions test standards and emissions testing equipment for 1998 and newer light duty vehicles, and prescribe two-speed idle (TSI) tailpipe test standards and emissions testing equipment for 1988 through 1997 model year vehicles. The current dynamometer test and emission standards prescribed in section 9 of the regulation would be revoked as of January 1, 2013. Also proposed is a change to the regulation to provide the Drive Clean Director the ability to enhance repair technician training and effectiveness.
The proposed regulatory amendments will ensure that the program continues to be effective in reducing harmful vehicle emissions of smog-causing pollutants such as nitrogen oxides (NOx), hydrocarbons (HCs) and particulate matter, as well as carbon dioxide, which is a greenhouse gas.
The proposed changes would modernize the current Drive Clean program to provide a more accurate inspection and increase the effectiveness of vehicle repairs. The proposed amendments are detailed below.
1) Eliminate the current Acceleration Simulation Mode (or Dynamometer) tailpipe test and emission standards and the fuel cap integrity standard prescribed in section 9 after December 31, 2012, and replace it with:
a) On-Board Diagnostic (OBD) test standards and OBD testing for 1998 and newer light duty vehicles registered in the Drive Clean program area, and require OBD training for all Drive Clean inspectors and repair technicians, beginning November 1, 2011.
b) Standards prescribed in section 8 and the Two Speed Idle (TSI) tailpipe test for 1988 through 1997 light duty vehicles and those vehicles that cannot be OBD tested, beginning January 1, 2013.
2) Allow enhancements to the future administration and delivery of the Drive Clean program including:
a) Authority over whether repair technicians who perform inappropriate or faulty repairs would be required to undergo additional training or be permitted to remain a Drive Clean repair technician.
b) Other Amendments
In addition to the environmental proposals detailed above, the ministry is also proposing the following administrative amendments:
• Removing obsolete sections of Ontario Regulation 361/98; and
• Assisting Drive Clean facilities, inspectors and repair technicians during the transition period to full OBD implementation.
Further Information:
Proposal Number: 09-MOE014
Posting Date: January 28, 2010
Comments Due Date: February 27, 2010
b) Other Amendments
1 Post
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
ehh... you shouldn't be complaining because 3/4 of our crap is done overseas.... ...
Car: 86 Trans Am
As for the topic, meant to add that I'm not sure if the visual check is still there but it probably is as these all talk about amendments to the existing specs.
1 Post
Engine: 5.1 4bbl
well... ... you still shouldn't be complaining as we have some of the strictest emissions laws in the world... specifically referring to California... although an OBDII vehicle, I don't see what the big deal would be to require emissions testing other than to collect fees... because if something is wrong with the emissions testing, getting a bad reading... freakin' car gets a mind of its own and sends your rear home in limp mode ....
Car: 86 Trans Am
yeah I know, I'm sure it's coming but I dread the day. I know its for the greater good but there are so few of our cars and older what impact do they REALLY have. Mine will fail visual cause I don't have an EGR valve with the new motor. Guess I could glue one on :P
1 Post
Engine: 5.1 4bbl
that's what I'm saying ... forgive the 95 and older vehicles from having to pass a sniffer test... I say as long as your vehicle is burning the fuel within specs, it should all be allowed...
Street Lethal
08-12-2015 11:33 AM
