Engine at Full Throttle !!!
Car: 1985 Trans Am
Transmission: 5 Speed
So i floored the car, and when the secondaries kicked in, the engine stayed at full throttle. So my first thought would be the pedal stuck, return spring broken and everything looks fine. I shut the car off, and when i start it now it goes into full throttle mode (even if i tap the accelerator pedal to see if i can loosen what seems to be stuck). Anyone have this happen to them?
1985 T/A 4 Barrel Carb (Quadra Jet)
5-speed Manual
305 LG4
5-speed Manual
305 LG4
the accelerator cable can do it too, it has two pieces that slide inside each other they like ot get caught on each other, i like to take a razor knife and cut off the sleeve on the front-most end of the cable so it doesnt get stuck in the main housing of the cable assembly
good luck
good luck
Happened to me once. Found that one of the spark plug wires would slip in behind the secondary cam when the motor made its shift.
took forever to find it too.
felt like a dipstick
Car: 1985 Trans Am
Well for some reason its disapeared, like trigger had mentioned, i disconnected the cruise control...but if it happens again i will keep all thats mentioned on here in mind. Thanks guys...happy cruising!!!
theshackle
09-17-2020 08:26 AM
