Camshafts
1 Post
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Camshafts
Ok guys, Im picking with your brains again.
Can you recommend a nice street cam that will wake up my engines performance thats not too crazy that might just use a 2400 stall?
I want the car mainly for pleasure cruising but I want that extra power, something mild.
1 Post
Car: 87 GTA t-top
For a TPI setup 350 87, I might have 1500 km on the engine, just a stock basic 350 from AcDelco, very plain and boring.
Needs a boost of something.
1 Post
Car: 87 GTA t-top
Forgot to mention, getting headers, stall 2500, shift kit, trans cooler, chip and cam/lifters as well, thats for this year.
Car: 84 Z28
Engine: Modded 350ci.
There are alot of options out there...where do you want the power to be? This will also make a difference of which cam you go with.
Personally i'm going to be running a Comp Cams Extreme Energy 268H. Mind you my engine isnt all that stock.
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
He's a 87 so a rollor, the 268 isnt, unless he got a flat tappet swapped in.
With stock heads/TPI, i'd go with a XR264HR (08-501-8)from comp cam's, its an actual TPI cam
http://www.compcams.com/Technical/Cu...ML/128-169.asp
The more mod's you do the bigger you can usualy go, TPI's dont like huge cam's though so your kinda limited as long as you stay a LTR set-up.
1 Post
Car: 87 GTA t-top
What do you guys think of these comp cams: 08-422-8, 12-210-2, 08-502-8
I have headers coming soon, might get chips, still debating...
The 08-422-8 (XR270HR) is basicaly the same cam as above but more for carb car's.
The 12-210-2 (268H) is a Flat tappet cam and more for carb car's.
Look more at the chart and you will see it actualy say's for TPI on cam's like 08-501-8 (XR264HR) or 08-302-8 (264HR-12)
Watch the lift lvl's or you'll start snapping the stock springs.
1 Post
Car: 87 GTA t-top
yea but the 08-502-8 is for setups with TPI that have performance chip, headers and stock stall, I will have both, doesnt specify anything else.
1 Post
Car: 87 GTA t-top
Problem is I have no idea about my engine specs and AcDelco cannot help me with this info either since its a discontinued item.
They tell me to call a local GM dealership to try and find out therefore its difficult finding a cam that suits me best without damaging anything.
All I know this is a reman engine stock 350 vin"8" AcDelco part # 12465201
Car: 1984 z28
dont take the chance, swap out the springs, its cheap insurance that everything will work right.
If you really wanna run the XR269HR-12, then D's89IrocZ has the part number for some Springs that are suposed to be good upto a .570 lift that mount in the stock seat's.
I'll send him this link if ya want them.
Or measure the spring pressure of the springs that you have. I saw a tool to do it while I was in the US although I don't know of anybody up here that has it and it was a little pricey. Other option is to take off one of the heads and take it to a good engine shop and have them give you the specs of the springs. They will test them for you. I would sooner take the head off now and be safe then take the head off when you are rebuilding your new engine because one of the springs didn't hold up.
I would say that your springs are rated at just under .500 lift currently but that is just a guess without doing one of the two steps above
1 Post
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Sd1007 springs from Scoggin Dickies Performance parts . 1.2" = 350lbs and 1.8" they are 120 lbs. good for .570 lift. and stock spring diameter.
But please contact them and ask them . I am running them on my ZZ4 camshaft in a stock headed L-98 .
88SS6SPEED
11-11-2015 07:05 AM
GTAman
09-26-2015 02:01 PM
