Is this a good cam choice....
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
I emailed the guys at Comp Cams to help me out with my fuel injected 327 project. I told them every single detail of my buildup, car, engine, exhaust, drivetrain, air/fuel. I asked them to recommend a cam that would be good for a high rpm fuel injected engine. Here is the reply;
Dustin,
The cam that I recommend is our part number 12-326-3. This cam will give you the performance that you are needing and work with the aftermarket setup on your computer system.
If you have any other question's, please feel free to either return
e-mail or call me @ 800-999-0853 ext. 543.
PART NUMBER12-236-3
ENGINE SMALL BLOCK CHEVY 265-400
GRIND # CS XM 262H-12
DESCRIPTION HYD ROLLER CAM
INT EXH
VALVE ADJUSTMENT HYD HYD0
GROSS VALVE LIFT .462 .477
DURATION AT
.006 TAPPET LIFT 262 268
VALVE TIMING OPEN CLOSE
AT .006 INT 21 61
EXH 68 20
THESE SPECS ARE FOR CAM INSTALLED
AT 110 INT C/L
INT EXH
DUR AT .050 218 224
LOBE LIFT .3080 .3180
LOBE SEPARATION 112.0 INT MASTER ID
ADVANCE 2 EXH MASTER ID
RECOMMENDED CC VALVE SPRINGS 981-16
Give some feed back on this, is this good or should I go a step up from this.
Dustin,
PART NUMBER12-236-3
INT EXH
DURATION AT
AT .006 INT 21 61
EXH 68 20
AT 110 INT C/L
INT EXH
DUR AT .050 218 224
I've heard good things about the 262H cam.
I think that for a street driven 327, it would be perfect. That's enough duration @ 0.050" for a healthy 350, and should help your 327 breath a little higher than average.
You're saying that you want high revs. How high are we talking? 6,000?
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
You might find that your TBI setup will have some pretty serious issues with that duration (218 @ .050). Not saying don't do it just that you will be spending alot more on prom work to get the TBI to run 1/2 way reasonably. Then of course you will be tossing that money out the window when you replace the existing EFI with a more aggressive system...
my .02 cents worth,
RP.
my .02 cents worth,
RP.
Hey guys, I would like to rev around 6000 and higher. Well currently I will be using an aftermarket TBI setup with some recommendations that Palric gave me ( cam setup), but I told the Comp guys I would be using a complete TPIS Miniram setup or the Holley Stealthram setup, as well as their wiring and ecm. I don't know why the lift is so low, I have stock heads but they have 2.02/1.6 valves, 3 angle grind on the valves, port and polish, dual springs, 1.5 roller rockers, screw in studs, guideplates, hi-perf pushrods, ect. I will be upgrading the fuel/air by the end of 2003 so I just wanted a recommendation on a cam to run with it. I will be running TBI for a good part of this year.
Thanks for your input.
junkcltr
08-02-2019 11:12 PM
