Need a HP estimate
Need a HP estimate
Im building up a 383 stroker and id like an estimate on HP.
Im putting on:
-Edelbrock Performer aluminum heads (2.02 intake, 1.60 exhaust)
-Underdrive pulleys
-Comp Cam (dur 218/224, lift 0.495/0.502, sep 110)
Let me know what other info is needed and what kind of HP & Torque I can expect.
Im putting on:
-Underdrive pulleys
I would say 320 to maybe 350 range. That tpi intake will really be killing it. What rods are you running. If you are putting in the 400 rod you will be losing a lot of your torque. If you are running a 6.0" rod you will hava a crap load of torque from 2200-4000. Sounds like you will have a torque curve that is really a table. Building is a 383 with a 6.0" rod is the way to go. Skip that 5.7" crap. Leave that to the rookies.
