Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Coverting 1/4 mile speed into 1/8 mile speed?
Old 03-10-2002 | 03:19 PM
Ghour_Demon's Avatar
I believe that the speed is always more reliable and accurate when compared to the time for 1/4 mile runs.
Some of you have said that to get 1/4 mile time from 1/8 mile time, you...
(1/8 mile x 1.55 or 1.56 = about 1/4 mile time)
What about the trap speed?
Say my 1/4 mile speed is 100mph, then what would my 1/8 mile speed be, say for a car with a theoritically perfect flat power curve. (same torque from idle to redline)
My current guess would be 2/3 that of the 1/4 mile, but I know thats way off.
Old 03-10-2002 | 05:39 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It's probably closer to ¾ of the ¼-mile speed; I was running between 95 and 96 mph in the ¼ last year, and my eighth-mile speeds were 74-75. But, my 60-ft times really suck - if the car could launch decent, it would likely change that relationship.
Check the timeslip in my sig, and then change the last number from 1 thru 9 to see some other vehicles eighth-&frac14 speed relationships.
Pete
Old 03-10-2002 | 07:32 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
my trap speed in the vette is close to 100mph. here are the results from my best run : (1/4 mile) - 13.66 at 101.82 ... (1/8 mile) - 8.80 at 80.12. my 60ft was 2.06. hope this helps
Old 03-11-2002 | 10:33 AM
CODY BEHNKE's Avatar
You cannot get your 1/4 mile speed from your 1/8. You just can't. I am not trying to flame but it is impossible no matter what. No math formula will answer 1/4 from 1/8, top spped, or 0-60.
Old 03-11-2002 | 10:49 AM
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
Most 12, 13, 14 second street cars pick up right around 20 mph (give or take a little) over the last 1/8th mile. That's the best guestimate I could provide you with.
For example, last season I ran 85 - 86 through the 1/8 and 106 - 107 through the 1/4. My dad's GT ran 79 through the 1/8 and 98 through the 1/4. My old convertible ran 77 through the 1/8th and 95 - 96 through the 1/4.
colton_carlson
03-08-2019 01:21 PM
1986Z28OWNER
12-13-2015 11:19 PM
jbd1969
08-17-2015 08:06 PM
kyleb24
08-15-2015 09:24 AM
1992 Trans Am
08-08-2015 09:16 PM
