why are people so retarded?
a guy in my class at school thinks he can beat him in a drag race in his 95 cavalier...whats a joke...looked up stats and they had like 115hp...he thinks he can take me because he has a manual and i have an auto what a jackass soon as i get a chance im gonna go kick his ***
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
guy at my work would always tell me that he could beat me in his cav and this was when I was N/A and so well we raced
he lost bad.....
he says somethingabout not getting a good launch or something like that and this was when my car was running 15.2
raced again
same result
he still to this day thinks his car is faster
he lost bad.....
raced again
same result
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
Originally posted by TBI305Camaro
what makes a automatic so much better for drag racing? dont yoy get more parasitic (i think thats what its called) lose outta a auto
After a certain HP level the auto has the advantages over a manual when it comes to power handling and shift speed. I don't care how good of a stick driver anyone is, they can't shift as fast as an auto with a race shift kit. Launching is also much easier, and as power increases so does the difficulty of getting a good launch with a stick (without breaking parts). Just some spare change worth of of info from lots of magazine and message board articles I've read.
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
manuals are better transmission if you need to make excuses for losing a race (ie, "i missed a shift" "I got a bad launch")
stock for stock manuals CAN be faster than an auto, but slap a TC and shiftkit in an auto and say bye bye. another added expense though
Car: 1981 Oldsmobile Cutlass Supreme Brougham 2dr Coupe
Engine: 403 Olds v8, bored .030 over
Transmission: 350 T.H. 3A, shift kit
Something about switching the gears manually makes barbie car drivers feel fast.
Feeling fast and being fast are two different things tho. Weren't the 3.1 and 2.8 cavaliers faster?
Car: 1993 Ford Mustang
Engine: 5.0L
5 speeds rule the streets. I don't know how many times I've lost to slower 5 speed cars on the street because they were able to downshift into a gear to put them in their powerband and I haven't been able to.
If you go to the track it's a different story. High stall converters, trans brakes, and manual valve bodies rule the track.
Auto vs Manual
Auto more reliable, dependable, consistent launches, much less room for error...wins most of drag races.
Manual requires great driving skills, but can be the quicker car.
When you take an automatic and shift it manually you are using a manual trans in my opinion. Something else is doing the clutch work for you. With true manuals you can have more gearing opportunities, and you can have "clutchless" manuals that require less pedal work built by companies such as Jericho. That enables the abilty to win against an equal automatic car (only thing being different in the car is the transmission, with both transmissions being designed to work with the rearend in terms of gearing)
It depends on your car, purpose of your car, and your driving capabilities and how much you are willing to sacrifice in terms of car parts, and practice. Automatics are easier. But a properly driven manual transmission is the one I bet on.
Pac J
05-17-2020 10:44 AM
