Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Tires????????
Old 12-27-2001 | 06:40 PM
idrag2's Avatar
Tires????????
What kind of tires do you guys run? How long do they last? And what is the longest lasting STICKY tire? Open for anything.....
Old 12-27-2001 | 06:49 PM
SoCo80p's Avatar
the best trade off is the BFG drag radial, it grabs the best and last the longest of a race type tire, probley get about 7,000 miles out of them if you take it easy, otherwise go with the absolutle fattest tire you can get under the wheel well, also go with a 15" rim, they will be you a little better traction then a 16 or 17"
Old 12-27-2001 | 08:45 PM
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
This subject is very open for debate...
The longest lasting sticky tire you can get is a Nitto drag radial, they'll last anywhere from 10,000 - 15,000 miles if you don't abuse them too badly. I've cut 1.9 60' times on these with an automatic transmission.
On the street I run Pep Boys Futura's 265/50/15. I've cut 2.0 60's on these and have seen 5 speed guys cut low 1.80's. They hook a lot better than the 295 series Firehawk SS I use to have on the car.
Up front I run 165 series Lemans tires. They're not the greatest quality tire in the world, but if you keep them aired up properly they're not too bad. At $29 a piece you really can't beat the price.
Old 12-27-2001 | 09:29 PM
Mustang5L5's Avatar
I run Pirelli P7000 Supersports on my car. 245/50/16's
They are Z-rated and hook very well in the dry and hook EXTREMELY well in the wet weather. I had a friend who had these on his car and praised them for their wet weather ability...which is why i bought them. There performance in the dry exceeed the BFG's and the Goodyear Eagles I had on there before
Old 12-27-2001 | 09:39 PM
NJ SPEEDER's Avatar
i am a big fan of the yokohama avs intermediate. i cut 2.0 60's on a road racing set up with these tires, got about 12,000 miles out of each set and they only cost like $105 each. they are also excellant in rain and snow.
later
tim
Old 12-27-2001 | 10:47 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
I currently have Michelin Pilot Sport XGT Z4s on my Vette. They are Z speed rated, and have been on the car for over 3 years. ive never had the car aligned, and the tread wear is perfect. I still probably have about a year or so left on these tires, they'll probably dry rot before the tread wears out completely. Oh, yeah, i run these at the track with 25 PSI and get 1.9 60 fts out of them.
Old 12-27-2001 | 11:16 PM
Joshua Leslie's Avatar
245/60/15(rear) 235/60/15(front)
BFG Radial T/A
50000 miles, white letter, classic looking. love em, they hook up pretty well to
Old 12-27-2001 | 11:19 PM
89WS-6's Avatar
I've got the BF Goodrich G-Force T/A's. They have excellent traction, and tread pattern. Just one useful tip, if you like traction get this exact model: the KD's not the K's or the KDW's. Just trust me.
Old 12-27-2001 | 11:21 PM
CobraKiller's Avatar
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
I gotta go with Nic saying the Nitto's are some of the best tires out there in my opinion. Alot of my friends run them on their cars and they all love them. Once I get a nice set of wheels i'll slap some Nitto's on the rear.
Old 12-28-2001 | 03:02 AM
20-psi's Avatar
I've used the Yokohama's myself and they seem the best for an all around tire. When I made my 12.42 pass I had them on. Got a 1.76 short time and almost lifted the front wheels off the ground. These tires are H-rated so the side walls are softer than Z-rated tirets which made them like slicks that have soft sidewalls. They were also cheap. I got about 25K miles out of them.
Pete
Old 01-05-2002 | 08:36 PM
Camaro8316's Avatar
I use Mickey Thompson Sportsman "I" tired in the back. These have the I shaped treads, really close together. They hook so good that with bad shocks, i popped the front tires off the ground more than once. I had them on the car for about 10,000 miles now and I still have about a couple thousand miles left. They're not that good in the snow tho!
LiquidBlue
Wheels and Tires
32
12-10-2019 05:06 PM
mattcanty
10-12-2015 12:08 PM
Quick Reply: Tires????????
