Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
roll racing with an a4?
Old 07-01-2013 | 01:51 PM
Savage388's Avatar
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
It sounds really stupid and simple but whats the least traumatic way to roll race with an a4? just mashing seems really hard on it especially on a 4-3 downshift with the shift kit, should i manually shift the thing? it takes forever for it to shift down too, my t-5 trans am was much easier from a roll.
Old 07-01-2013 | 01:55 PM
Guest
Guest
Posts: n/a
Re: roll racing with an a4?
I always "downshift" into third if I'm going from about a 40 roll. I have to be careful about not slamming it into 2 though, damned auto.
Old 07-01-2013 | 02:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
You have to know what speeds are best for each gear. If the tranny is setup right, it should down shift very quickly as long as the speed is right. You have to experiment.
I also used to manually shift my 700r4. Occassionally i would hold gear for a roll but it may not be good for the tranny unless its got a manual valvebody and is designed to hold gear. My favorite was to do a 5000 rpm first gear start. On warm day tires would hook and car would rocket ahead with out any delay from a downshift. This was a slow roll and from 5000 rpm, shifted at 6800, it went by in a flash so needed to be quick on the stick lol
Autos arent bad from a roll in certain applications, just need to get them in the sweet spot
Old 07-01-2013 | 02:59 PM
s10sbc350's Avatar
Car: 91 Z28 camaro
Engine: L98 from 90-92 camaro
Lol off topic but I thought you meant whats the best way to race an Audi a4 from a roll
Old 07-01-2013 | 09:34 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
It depends on the trans, most will downshift to 2nd at 40mph - right at the sweet spot in power usually.
Personally in my Camaro I let the trans downshift to 2nd and then manually wind out the gear (it short shifts).
Old 07-01-2013 | 11:08 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I always manually downshift. The gear you choose depends on your speed though obviously.
Old 07-02-2013 | 08:23 AM
Street Lethal's Avatar
Originally Posted by Savage388
It sounds really stupid and simple but whats the least traumatic way to roll race with an a4? just mashing seems really hard on it especially on a 4-3 downshift with the shift kit, should i manually shift the thing? it takes forever for it to shift down too, my t-5 trans am was much easier from a roll...
Sounds like something is wrong, you shouldn't be racing with it. Try reaching out to Dana in the transmission section, because it sounds like it is either that your detent cable isn't set correctly, or perhaps your throttle valve or governor are suspect. Either way, properly built stalled automatics are pretty tough to contend with from a roll, when properly built...
Old 07-02-2013 | 06:42 PM
transamws6's Avatar
Car: 92 trans am ws6
Axle/Gears: 3.42 ls1 rear end posi
I AGREE something is wrong my auto was quick to shift and strong to roll....
Old 07-02-2013 | 08:09 PM
Although the following is a boosted run and from a dig, a Syclone vs an EVO, when properly built, and automatic will own a stick on the highway, when properly built...
Old 07-04-2013 | 12:46 AM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Being the owner of both a 305 auto an a 350 T5 I think Orr89RocZ hit the nail on the head. You just have to learn the sweet spot with the auto.
The 305 auto seemed the most impressive at around 25-30mph. At WOT It would drop to first and take off. It was also impressive at the 3-2 downshift. However at any other speed it always felt as if it was out of its power band. Either is at the bottom or top of the gear at WOT.
My 350 seems much more quicker. Not soo much that it's got more power, I believe more so of the extra gear. I can always get into the RPM range I want. At pretty much any speed.
Old 07-05-2013 | 03:17 PM
Savage388's Avatar
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
it's a 4l60e if that helps any, even from a 50 roll it downshifts to second. I do have a feeling something isn't quite right in there.
Posted from Thirdgen.org App for Android
Old 07-06-2013 | 03:15 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
It should be dropping in to 2nd at 50mph. I'm slightly confused though. You said it shifts really hard? But you also said that it doesn't shift immediately is that correct?
You do want it to shift hard though.
Unless you're caught off guard then you should manually downshift to the best gear for that speed and then start the race from there.
Old 07-07-2013 | 04:48 PM
Savage388's Avatar
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
yea theres a small delay from when I floor it to when it kicks down and the shifts don't seem to be as fast as they should. i could just not be used to the auto yet though.
so it'll be okay to down shift it manually? I'd rather do that then let it downshift itself.
Old 07-07-2013 | 06:34 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Absolutely. Just make sure you don't drop it in to first though LOL
ANYTIME I think I may race someone i will manually hold the gear I'm in just so that I don't get caught off guard. I don't want there to be any confusion about who won the race.
Old 07-18-2013 | 03:53 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
When I race from a roll I usually start off in second gear and punch it, rap it out then slap it into third and ride it out until I absolutely have to shift into forth. That's what has always worked for me. I do the same from a dig so that the drop from second to third isn't so drastic.
Old 07-18-2013 | 09:48 PM
Kevin Lee 487's Avatar
Car: 1999 Trans Am Ram Air
I'm confused. Do you start a dig in 3rd somehow?
I'm going to assume its a massive typo.
Old 07-22-2013 | 02:16 PM
Savage388's Avatar
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
okay, turns out my problem was the fuel pump that caused it to feel like there was a delay when i nailed it and the trans was slipping. ill try dropping it to 2nd manually at about 40 and see how that goes with the new pump, it feels a lot peppier now.
Old 07-23-2013 | 03:12 AM
no I start a dig with the shifter in second gear, let it rip out first and second then manually shift into third, let third ride out and then shift into fourth.
Old 07-30-2013 | 05:06 PM
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
So does that make you take off in 1st or 2nd?
Old 08-01-2013 | 03:40 AM
I start in second
Old 08-09-2013 | 02:04 AM
jaybdaboat's Avatar
I start in second
Launching in drive seems like it pulls harder to me tho
Cam-aro
Camaros Wanted
11-12-2015 04:35 PM
BrianChevy
Wheels and Tires
10-13-2015 01:33 PM
darwinprice
17
10-12-2015 12:51 AM
gord327
10-03-2015 02:25 PM
FormulaEngland
09-30-2015 02:50 PM
