The immortal question...Who Will Win!?
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
Alright here's the matchup..my fresh out of the shop 87 IROC 350 autp which has run a best of 13.8 on slicks with some minor wheel spin(how i did that on slicks is beyond me) against a 92 eclipse GST turbo 5 speed which is running approx 10-12lbs boost,catback exhaust,bigger cams(not sure on exact specs),and a blow off valve. He says he's gonna toast me. I think if i spin off the line he may just do it..what does everyone else think? I mean he's beaten my lincoln lsc 5.0 and now he thinks he's ready to take on the world..hehe all input is appreciated especially since he wants to put $100 on the line.
"Turn a 12 second dream into a 10 second reality"
Car: 1993 Ford Mustang
Engine: 5.0L
I think if he gets a good launch you may have a good race on your hands, but he's got to get out of the hole hard and get into boost quick or you'll walk him.
1989 Mustang LX 5.0 Coupe
13.29@106.66 - needs more gear and converter
1992 Mustang LX 5.0 Convertible
14.23 @ 95.something - 100% bone stock motor - it's been a while since I've ran this one
1993 LX 2.3L Hatchback - "The Ride to VCU"
Moderator Stangtec.com, SN95.com
Co-Founder, Tri Cities Mustang Club
Amelia and Nic's Twin Terrors
Car: 85 Trans Am WS6
Engine: 305HO L69
i think he just might take you, those things are pretty quick, and he'll probably hook up a lot better than you, it's awd right?
87 Camaro LT
bone stock 305 w/ 700r4 0-60: 3 minutes
mods to come:
ground effects
93 camaro seats
99 camaro center console
91 z28 rims
white 145mph iroc gauges
87 Camaro LT
mods to come:
ground effects
93 camaro seats
91 z28 rims
Nope the GST is the front wheel drive turbo..and now that you mentioned the AWD factor I think he'll be using slicks also..i forgot to mention that
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
all gonna depend on traction on this race....you get him well of the line you'll probably win, one thing though..you said he runs 10-12#'s, make sure he's running that when u race..a simple turn of a **** can increase his boost without u knowing
*89 Trans Am GTA
*Moderator at www.transamgta.com
To hell with the GM vs Ford war. We must unite, as brothers to fight the plague that is overtaking the world...RICE
Tony
*89 Trans Am GTA
Tony
Car: 99 Formula
Axle/Gears: 342
I'm going to say he'll hit low 13's.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
<font face="Verdana, Arial" size="2">Originally posted by CobraKiller:
92 eclipse GST turbo 5 speed which is running approx 10-12lbs boost</font>
just my $.02
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*SLP 1 and 3/4 headers with 3 inch catback
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*eibach pro kit and hotchkis sturt tower brace
"There is no way you have a 350 in that car. They are made to have 305's and a 350 wouldnt fit"
-local parts store genius-
Car: 1989 Iroc Z L98
<font face="Verdana, Arial" size="2">Originally posted by cobrakiller1989:
Im pretty sure 10-12 pounds is very close to stock boost on this car. FWD is gonna be alot harder to hook than you RWD. If you race at the track i think it will be close. If you race on the street and you ease into the gas and dont spin the tires. then i think you will definitely win.
just my $.02
</font>
just my $.02
</font>
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
have to watch it with turbo cars
little change here or there and they can up the boost.
also with turbo they make good power through a wide powerband rather the n/a
though FWD does have the problem with hooking cause right when he gives it gas all that shifts to the rear of the car.
either way it will be a good race
imports are cool - ricers suck
ICQ 4116192
AIM RXspeed87
Got rotary?
running a turbo motor with 12psi.
full dual 3 1/2" pipes comming off the turbo
FMIC,CAI, ram air, e-fan,
soon to have ported intake,TB, and motor
best time 12.5 on G-tech
prev best time 14.8
hoping for 11.x soon :-)
but I broke another driveshaft...
and still running full street trim :-)
ICQ 4116192
AIM RXspeed87
Got rotary?
prev best time 14.8
<font face="Verdana, Arial" size="2">Originally posted by unknown_host:
I'm not sure with all fwd, but from my experience it is way easier to hook fwd cars than rwd simply because all the weight is over the front tires. however, i would like to say you will win because i dont like thinking about fast imports heh.</font>
*1989 RS
*355 CID
Last i recall those cars run 14PSI boost stock, but thats besides the point.
If the only mods he's done are what you listed, you'll take him if hes just FWD. On a DSM (talon or eclipse), cams should not be done until after lots of other stuff. If he's not running a bigger fuel pump and hasn't upped boost to about 16 psi or so the race is yours. just my figurin' though.
88 Camaro (The mighty LO3 SC!)
305TBI/700R4/2.73/125,XXX miles
10" Open Element and Flowmaster 80 seires
Bosch Platinum plugs
Double silicone Accel wires
Next up: headers and gears
<font face="Verdana, Arial" size="2">Originally posted by 89mustang:
I saw your trap speed, and all you need to do is hook that car up and you should walk all over him. At 104 you could hit low 13s and I'm pretty sure that will take him.</font>
Actually the engine up front idea isnt that good. Weight transfer is what matters. when you launch a car all of the weight goes to the back of the car. In a front wheel drive car with 80 hp you can floor it and spin the front tires for this exact reason. In a rear wheel drive car. with about 250hp you will get similar results. because all of the weight is going over the back tires. now a rear engine car with RWD would probably be the best one of them all as far as hooking up goes
</font>
</font>
Hotrodboba400
12-10-2019 07:07 PM
Angie Coots
09-23-2015 07:42 AM
