GALANT VR-4 vs 25th annv. z28 with 350 engine
Car: 89RS-5.0/88IROC-Z-5.0/92-5.7 z28/v6
Engine: 5.0/5.7/2.8
Transmission: 5 spd in two stock auto in other tw
Axle/Gears: stock
just wondering which one do you guys put ur money on
buth rugged cars need tune up
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: GALANT VR-4 vs 25th annv. z28 with 350 engine
8th gen gallant vr4 M5speed would stomp all over a 25th anni 350. The camaro might have the vr4 off the line but after that the vr4 has the camaro beat in just about every aspect. On a road course the camaro might win.
The 7th gen vr4 against stock 25th camaro would be a good race.
Engine: 5.0/5.7/2.8
Axle/Gears: stock
6th gen 1991 galant vr4 with 3" exhaust and 16g turbo
Car: 1985 IROC-Z
Engine: 355
Is that the stock turbo? Also is the boost tuned up. Is it dyno tuned? What PSI is ti running?
With the boost turned up and a good tune that thing could easily be a low 14 sec quarter mile.
Engine: 5.0/5.7/2.8
Axle/Gears: stock
no its not stock turbo stock turbo is 14b
it has an upgraded turbo to 16g running 10lbs of boost that 3.5lbs over stock boost
id say since stock the car has 195 hp
id say the cars at 250
with the new turbo,,new exhaust,
car is not tuned its running on a self management system
Engine: 5.0/5.7/2.8
Axle/Gears: stock
and internet says it can be a 9 sec car its the same layout as
an ECLIPSE GSX its got ALL WHEEL DRIVE except for the gvr4 also has ALL WHEEL STEERING
Car: 1985 IROC-Z
Engine: 355
Are you sure you are talking about the right motor, 6th gen Stock the 2.0vr4 motor pushed~240hp. Even If the upgraded 16g was running on stock boost it produces more cfm. more cfm=more hp. IMO with a 3'' exhaust, and tune it should be making 300+ hp.
Engine: 5.0/5.7/2.8
Axle/Gears: stock
You nust of read the europe gvr4
Us supossedly had 195 or maybe I read wrong
Its the 4g63 motor
Its the 4g63 motor
Car: Escort GT
Engine: 1.8
Transmission: Stick
Axle/Gears: Both
I gotta get ALL WHEEL STEERING on my car, so I can do 9's. That would be awesome.
Engine: 5.0/5.7/2.8
Axle/Gears: stock
Engine: 5.0/5.7/2.8
Axle/Gears: stock
just bought the vr4
theshackle
03-05-2017 06:37 PM
NinjaNife
08-23-2015 11:49 AM
