Question who do u think would win
Car: 1991 Gta trans am
Engine: 383ci,trickflow alum. heads, hsr
Transmission: T-56, alumin. driveshaft
Axle/Gears: stock 7.5"/3.42
Ok this is a race between two thirdgens. Camaro vs 91 gta
Camaro mods as follows... 350 4 bolt main, alum heads, cam 240? duration ? lift supposely, high rise intake, don't know carb, true dual exhuast, th350 w/4000 stall, don't know rear gears but lets just say 4.10s
91 gta mods as follows
383 stroker, trickflow heads, comp cam 230/236 .571/.576, full roller block, 2 bolt main fully balanced, ported HSR, hooker shorties with 3" catback, 10.3 to 1 cr, t-56 w/zoom HP clutch, 93 rear w/ 3.42s, deleted smog, PCMforless tune, sfc, no spare tire. lol
Well what do u guys think?
BTW both cars on street tires.
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Re: Question who do u think would win
Would say the GTA but wat kind trans dose it have?
kevin
kevin
The GTA has A t56 six speed manual.
Ya if you can drive i think you should take him but its going to be close i think.
kevin
kevin
I can drive especially when it counts.
but I know I can't beat an auto in shifting if its built.
However its a friend of mine who seems to think that my car is slow..cough (he drives an s2000 and a crapy 87 rx7 turbo) both I've beaten and never have to go past like 80mph because I have like 3 cars on him and he thinks his cars r reeling me in everytime I shut mine down.
I guess since he can't beat me. he is trying to be mr. know it all and get me to race this kid who, with his last build lost to my buddy's pos civic. Its a new build now but the kids car shifts at 6000rpms like I do in mine when I race so I figure cubes and gears have to be the factor in this race right?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
well, since we have pretty much no info on the camaro other than its a camaro and an automatic, its kinds hard to tell. If the maro has a 4000 stall converter, its probably a very strong runner, or a mish-mash of unmatching parts
i think the camaro will win chances r good your 2 bolt will break and so will your t56.
your car by your parts doesnt seem that fast prob. like a high 13.
i dont think your heavy car would beat a turbo rx7. and who shuts down at 80. a real race is atleast to 120. 80's not even an 1/8th mile.
i hope u can drive cuz the t56 doesnt shift as good as a stalled automatic
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
So if his car is truly a high 13 second car as you predict why would it break a 2-bolt main block and T56?
He absolutely has a solid 12 second car, his 2-bolt main block is fine, as his is T56...and turbo RX7's are slow in stock form.
...so yeah.....not a good way to start your first post. You might want to start doing some research, it'd help you look better in the future.
Car: 91 GTA
Axle/Gears: 3:73
this guy is not serious, this is all bs
It sounds like you have a well balanced set up wit your gta. the camaro seems to be the wild card here. I bet you have a good 10mph on him in the 1/4.
should be a good 1!
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Don't know enough 'bout the Maro, however if it is a12 second car, you'd be lucky to win, in a 1/4????? Gearing is everything in the 1/4, on the other hand 3:42's get him on the open road!!!
Car: '82 Z28
Lets see... he's automaticly going to break because he has a 2 bolt main. Humm I have one as well and haven't broke in the 5+ years the engine has been in the car. Have a look at the times I'm running in my sig.
No way he'll be running high 13's unless the car is 5000 lbs or has zero traction.
2. Why shut down at 80mph....well I know that there's just no way I'd be able to keep pulling til 175mph so I give up before he passes me at 300mph cuz we all know rx7 have top end.
Car: 5 cars
with the eception of the tranny and stall (i have a 700r4 with 3000 stall)....and the guess od gears.....(mine are 3.73's)
the generic discription of the camaro could in part describe my 84 t/a that runs 12.2@112mph na or 11.8@119 with 125 shot.....no traction eitherway
so i guess more info needed!!!!
BlackphantomZ28
08-22-2015 01:00 PM
Linson
08-21-2015 02:12 PM
