vw 1.8 turbo
Car: 92 Firebird Formula
Engine: 5.0 tpi
vw 1.8 turbo
My friend in a vw 1.8 turbo (not sure of year, but newer) 5 spd. says it will beat my 92 formula 305 5spd. with flowmaster exhaust, and a newer clutch. What would the outcome be?
Engine: 5.0 tpi
Re: vw 1.8 turbo
I went for a ride in it today and it seemed quick but not fast. I know I can get a jump on him from a dig but getting into higher speeds he will pull on me. It felt close to what my can do
Car: 1988 Camaro Coupe
Engine: 305 5.0 L03 TBI
Transmission: T5 - 5 speed
Axle/Gears: open diff. & stock 3.08 gears
Re: vw 1.8 turbo
i pulled out of a local weekend race spot and im next to a 1.8t jetta with a front mout intercooler on it, i did a first gear pull with him and i had him bad so im thinkin you should get him.
Re: vw 1.8 turbo
i am unsure, when i went to the drag strip i seen 1.8ts running 15-16's
Re: vw 1.8 turbo
And just because he has a front mount, doesnt mean he has anything else. Ive had a few putz'es(is that a word) come into my shop with a front mount and nothing else done.
1 Post
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Re: vw 1.8 turbo
You never know what your getting into with one of those 1.8T's. It doesn't take a lot more than a tune, intercooler and exhaust to find 300 crank horsepower, which would beat an L98. Any Fbody should be able to get a holeshot on one, but don't count on stay in front for long if your relatively stock and he's built.
For comparison, my modded LG4 run pretty good with my cousin's Audi TT, which is a 225hp variant of the 1.8T, I put both the car's at about a 14.6.
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Re: vw 1.8 turbo
Stock they are nothing to write home about, but pull alright through the RPM. Modded they have good potential. Simple stuff and you have an easy 14 or even 13 second car. My friends 20th ann. GTI with FM, diverter valve, CAI, KO4, turbo back and a tune runs pretty hard. Probably a middle to lower 13s car if you can get it out of the hole and into second without destroying the tires.
1 Post
Car: 1986 Camaro SC
Re: vw 1.8 turbo
There in lies the key. All the front wheel horsepower in the world doesn't do much good when it can't be put down, and it frequently can't. I've seen plenty of cars at the strip run 13 second passes at 120+mph.
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Re: vw 1.8 turbo
I have driven it, a good driver can and will get the power down. A 13 second at 120 car sucks from a light, but from some mph will be a whole new ball game!
Re: vw 1.8 turbo
Not quite....Roughly 250-260 crank is the most you can possibly get with the stock turbo. They are extremely small.
1 Post
Car: 1986 Camaro SC
Re: vw 1.8 turbo
Must be I'm basing my info of the Audi TT (the 225hp 1.8T version), I'm not sure what the difference is, but there is documentation of guys getting right about 300 crank horsepower on that model of the TT. Maybe its a different turbo, or there are more difference between the two motors than I know.
1 Post
Car: 1986 Camaro SC
Re: vw 1.8 turbo
From what I've read/heard the TT motor has a lot of forged components, and is pretty well suited for upping the boost, increasing the breathing, and making some pretty respectable power, especially given the displacement. I know my cousin's nearly stock TT is every bit as fast as my 5 liters, and he's only got 1.8. Althought, my 5 liters on 8psi would be a totally different story.
Re: vw 1.8 turbo
New2Chevy
09-28-2015 12:35 AM
