Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
87 l98 VS 95 5.0
Old 08-23-2007 | 06:22 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
87 l98 VS 95 5.0
My friend got one, There only rated at 215 hp (5 speed)
My car is converted to a 5 speed, Has Zz4 cam and 24 pound fuel injectors.
Other wise stock
Old 08-23-2007 | 06:26 PM
92droptopws6's Avatar
Car: 90 RS
Engine: 5.0 TBI
Transmission: Slushbox
Re: 87 l98 VS 95 5.0
you should beat him without a problem,traction may be the only factor for you
try to feather it out of the hole,HE CANNOT TOP END YOU
Old 08-23-2007 | 07:08 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
as i figured, haha
Yeah i will have to be easy because my posi is wearing out 2
Hopefully this will happen soon so i can let u guys know
Old 08-23-2007 | 07:32 PM
Car: 90 RS
Engine: 5.0 TBI
spank his butt then shake his hand
Old 08-23-2007 | 09:31 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
haha i will, he keeps saying its a special edition an all that jazz
its not a cobra so im not scared... cant wait to race this kid :P
Old 08-24-2007 | 06:18 AM
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Is his bone stock, or "mustang stock"?
Old 08-24-2007 | 06:58 AM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Other wise stock
I'd be confident in my lightly modded LG4 beating that particular mustang, given he's stock. I could routinely pull the slightly heavier 95 5.0 Cougar my buddy had, and that was with my low 15 second Grand Am, we never got to make a run against the Camaro, but I can tell that the Camaro smokes the Grand Am pretty easily. I would think a stock L98 would have the win pretty easy win, with a cam it would just be even less of a race.
Old 08-24-2007 | 04:45 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
I looked at the car, its in between from what i saw a Cold air intake, and gutted cats with a stock exhaust
Maybe a throttlebody but i didnt see anything below that unstock
... Heres what he just sent me "just research it! 285 hp get over it cry baby."
Hahaha he is going down!!! I just got my injectors in today.. SHELL fire up by tomorow!
Old 08-24-2007 | 04:53 PM
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
He thinks it has 285... oh boy! Yeah I think you should take him.
0uTcast13's Avatar
Car: 1988 Pontiac formula Firebird
Engine: 5.0 h.o.
Transmission: 5 Speed
Axle/Gears: 3.55 10 bolt
with a good driver that could be deadly i had 1 with gears and intake and OK tires i was running 14.8 14.6 then i got my cobra intake and short shifter and a good clutch long tubes i was running low 13.8 but i could not hook so be careful if he is a good driver it shall be a good race good luck and beat that stang
Old 08-24-2007 | 05:05 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
btw 25thmustang, is that your stang in your avatar??
Thats beautiful... i normally dont like them to much, Besides my uncles 90 notch with a 302 bolt on with 7 psi makes about 600 to the rear wheel :O
Old 08-25-2007 | 03:23 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
It takes more than 7psi to put out 600 hp at the flywheel let alone at the wheels with just a "bolt-on" 302
Old 08-25-2007 | 06:11 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
before he had it tuned it made 523 rwhp, and 540 ft pnds of torque
he has a stock block with forged pistons, trickflow heads, 42 pnd injectors, and a cobra r intake.
and he has turbo headers, y piped to the intercooled turbo and a 3 and a half inch downpipe dumped under the floor.
Hes in the process of tuning it now, and just yesterdathey had it running lean and picked up about 50 horse, and they still have a ways to go
Old 08-25-2007 | 07:38 AM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
An it still takes more than 7psi to make that kind of power from a 302!
Old 08-25-2007 | 11:41 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
Well, its my uncles car not myn.. I cant exactly say he isnt not telling me something
Ive seen the dyno sheet but hey, whatever mustangs arent my specialty anyway
Old 08-26-2007 | 11:43 AM
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Yes thats my car, and thanks I just got it back on the road and back on the race track.
The motor in your uncles car sounds stout, but there was no Cobra R specific intake, so it might just be a stocker Cobra. Other than that I assume its a simple HCI car with a small turbo on it. The power he made seems alright, but 7psi seems low to make that. I figure 8-10 would be a minimum unless there is work he isn't telling you about. All in all still a fast car I'm sure.
Old 08-27-2007 | 07:56 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
yeah, its a quick car, and still has alot more in tuning
I just got my car fired up today, Kinda rough :/ I need to adjust the valves because the vacuum gauge was flucuating between a solid 19, then jumping 15-10-15-10
Old 08-29-2007 | 11:05 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
7 psi, of how much air dudes? and at what temperature? compression ratio? lotta variables left on the table to write that off. also rpm, if it spins to 6500-7000 that's a big difference.
Old 08-30-2007 | 09:15 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
Ive seen the dyno sheet, i dont have it
i just saw the numbers, and dont remeber the rpm.. But if u guys are dead set on saying it doesnt make that horsepower thats all well and good
Old 08-31-2007 | 12:26 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
it's a stretch but not as huge as they make it out to be. hp is dependent on rpm, and people that base power in a turbo car on psi alone haven't spent much time in the turbo scene. i haven't either but i've seen plenty of "noobs" on 240 sx forums asking how much boost it takes to make x amount of power and they get the talk that psi isn't even close to the only number that affects it. how large is the turbo, whats its efficiencies, a/r ratio,lots of stuff. if you have a turbo the size of say my fathers in his 5.7 liter turbo diesel, you can push 500 hp stock. why? rediculous torque, my t/a fears that damned dodge...
Old 09-01-2007 | 05:08 AM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
I agree but only 7psi?do you really think that you could put out over 600 whp with that amount of boost with only 302ci and a couple of bolt ons?i say prove it!!
I'm not calling you a liar at all if you have seen the dyno sheet then its all good i just think theres more to the car then what he has told you because those are pretty big #'s for what your telling us,thats all
It doesnt matter if you have the best turbo money can but if the entire package doesnt work it wont make power!Im not trying to say that a 302 cant make 600whp im just saying it cant do it with only 7psi,sorry for any mix ups
Old 09-01-2007 | 11:00 AM
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
A 302 could do it with 7psi, it's just a matter of what HCI set up, and 7psi from what, like stated before. A solid HCI car done right, with a larger turbo making 7psi, could put down that power.
Old 09-01-2007 | 02:00 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
its a BIG turbo, sposed to handle 1200 horse power.
Old 09-02-2007 | 10:47 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Other wise stock
Make sure you get your eprom adjusted for the larger injectors or you'll run far too rich and loss power. If you spent a little more time on the spark advance, you could gain even more. A properly "hands-on" tuned eprom could gain you up to 4/10ths (half for the fuel and half for the spark).
Old 09-02-2007 | 04:44 PM
BadBowtie88's Avatar
If you just put injectors on, and nothing else, you're not really gaining anything. As far as the post goes though, I think you'll have the mustang in a race.
Old 09-02-2007 | 08:34 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
its got a cam in it 2
and yeah i am going to order a 89 chip from TPI parts, with the injector size 23.8, and also im thinking of getting the vette spark chart
Old 09-03-2007 | 01:01 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
the 94-95 5.0's werent special but im sure if you spun out of the whole you would have a hard time catching up on the top end TPI is good for out the whole and low rpms that 5.0 im sure has more 5000+ power and torque then your l98 so im sure you can top end you
91chevyz28
02-10-2022 07:58 PM
FormulasOnly
07-23-2018 08:47 AM
sammy52401
11-11-2015 07:20 PM
89bird2.8
09-22-2015 05:28 PM
Mr. Chevy
09-11-2015 06:06 PM
Quick Reply: 87 l98 VS 95 5.0
