N/A MKIV Supra vs 92 RS V6
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
one of my best friends owns an MKIV supra yesterday we decided to race, his mods were cat back exhaust 2 1/2"-3" i dont remember which and cold air, he said around 240hp running low 16s in the 1/4, my car was a 3.1L LHO, my car was all stock only mod i had was the k&n filter. round 1 we start from a dig and go to 80mph. i got a bad start and he got 1/2 length head. after i hit 80mph he was about 2 car lengths ahead. both of our cars r 5 spd manuals, except our clutch were about to die, only raced once cuz my clutch gave out and that was the end of that. not bad for a stock camaro, can't wait tell he puts a t-61 turbo in his car and i have my LT1 goin to be a race
Engine: 3.1L V6
Re: N/A MKIV Supra vs 92 RS V6
both r clutchs are about to die, he is not that great of a shifter. i perfer the LT1 over the lsx series because 1. its cheaper and easy to find 2. its iron block a little stronger over the LSx series 3. an easy swap to do. keep in mind we're only 16 both the kid w/ the MKIV supra and me
Car: 91 Z28 and a Jeep Grand Cherokee
Axle/Gears: C.E. Ford 9 Inch, 4:10's
A LT1 may be cheaper but I wouldn't say they are any easier to find then a LS1. I wouldn't say a LT block is stronger then a LS block either, LS blocks are 6 bolt mains and guys are running 600 hp safely on stock bottom ends and the LS series also responds to bolt on / all mods better. They do also make iron LS blocks. I would agree though the LT swap should be easier.
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
Engine: 3.1L V6
ya he is no good at shifting, i dont understand y he isn't good hes been driving a manual since he was 14 years old, he got the supra when he was 15, and still isn't as good as me i just learned how to drive a manual last year. but still u got to give him props, how many 16 year olds have MKIV supras? hell many kids had a thirdgen Camaro. not too many
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Why don't you swap a Cobra motor into your car then your name and pic would be appropriate.
Car: 1989 i roc-z28
Engine: 350 tpi l98
be carefull with those supra's espically when they are playing with boost. a buddy of mine has a mk3 with a 70 trim turbo and he will be right on my *** even with the 100 shot.
