TPI Camaro vs. L98 Corvette vs. 4.6L Mustang...all modded (who'd win??)
Car: 1990 vette
Transmission: ZF6
Well, going to Maple Grove this spring, and me and some buddies have some money down on a few 1/4 mile races. I was wondering who'd win, and what order.
What I got:
-1990 Corvette L98
-350 bored .040 over (stock CR)
-6-speed
-4.11 gears (I know, but they're fun on the street)
-aluminim 113 D-port heads
-1.6 full roller rockers (with LT4 valvesprings)
-Hooker long tube headers
-No precats
-Flowmaster 40 series mufflers
-siamesed/lightly ported stock base
-K&N filter
-AFPR
-Custom tune by PCMforless.com
What they have:
1.)
-1990 Camaro 350 TPI
-5 speed
-Roller rockers (1.5)
-True dual exhaust (H-pipe)
-Edelbrock manifold and runners
2.)
-2001 Mustang GT
-5 speed
-high flow fuel pump and 42# injectors (for a future supercharger)
-PI intake
-3.73 gears
-Roush side exhaust
-Headers (unsure as to brand)
-K&N intake
-50hp nitrous shot (Sneeky Pete system: I've seen it, I don't know if he'll use it since it's only good for a run or two)
So, dead stop, to a 1/4 mile, who'd win? I'm hoping, and betting, it's me. All of us are using street tires, and shift and reaction times are nearly equal.
What I got:
-1990 Corvette L98
-6-speed
-No precats
-K&N filter
-AFPR
What they have:
1.)
-5 speed
2.)
-2001 Mustang GT
-5 speed
-PI intake
-3.73 gears
-Roush side exhaust
-K&N intake
1 Post
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
my old 89' Vette went 13.16 at 104.79mph... but your car has headers, gears, rockers, and a 6speed over what i had. if you can drive, your car should be an easy mid 12 sec Vette. if i were you tho, id get some sorta drag radial cause with the TPIs torque + 4.11 gears your gonna be fighting for traction off the line
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Good move on siamesing the intake, you've got this covered by a long shot. The only thing that could be limiting you is that genero tune, hopefully they got it close. As for 4.11's being to much; they are until you throw a siamesed base into the mix to even things up a bit. Oh btw you never mentioned who has what for tires? You should definetly look into some ET Streets or straight up slicks.
Car: 1990 vette
Transmission: ZF6
I'm running Goodyear street tires...forget the exact model. They're about the same....all Z rated.
The tune isn't really generic...they tuned it after I sent in my data sheeet of the table values from my laptop program.
Car: 1986 Camaro Berlinetta
Engine: 4 bolt 355ci
Transmission: Borg Warner T-5
Axle/Gears: 3.73 Posi Disc Rear
Sounds like you got it in the bag, but everyone is right, get some stickies or Drag Radials.
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
if you get traction and can shift fast. that thing should be fun on the steet. you pro go though gears like a crotch rocket.
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
I would go with the vette but the mustang would not be to far behind with a 50 shot. My brother is running 13.5 with his 90 L98, 700r4, vette with similar mods.The vette could run low 13s and the camaro would run high 13s.The mustang and camaro are probalby a decent match before the spray.4.11's are nothing in a 6 speed!!! Runs like 3.23's in a 700r4. Very common mod for t-56.
1 Post
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
better watch the stang though. I've got a 2006 Mustang GT and while my 89 Camaro TPI 350 jumps it off the line, up top it catches me..
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Headers, gears, filter and a catback on a newer car is a higher 13s car. The injectors are hurting it a TON. Instead of getting a nice solid injector pulse, those injectors are flowing so little of their potential they are actually merely spitting fuel into the chamber. Trust me, 24s are too big on a stock motor, these injectors are running at such a low duty cycle hes probably losing anything the other mods helped with.
Ad a 50 shot to that, mid 13s at best!
Car: 1990 vette
Transmission: ZF6
So general consensious is I should win. Good! I need some college money.
It's a test and tune/grudge racing day....so I'll se what I can coax out of her.
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
You.
Then the Mustang (if he can drive and get a good launch), otherwise it should be pretty close b/n the stang and the camaro.
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
I think you should have the win. By the way in response to zz4monte about the 4.11's being a common T-56 mod, isn't his the ZF 6 speed? I'm not sure but I think it is, and it probobly dosen't make much difference.
It probalby is a ZF but either way 4.11s just don't effect your cruise speed with a 6 speed like they do to a 700r4.
Car: 1990 vette
Transmission: ZF6
Yes, the ZF-6 is a 6-speed. I cruise 85 at around 1900RPMS
Looks like I will be buying new tires for the 'vette, since it needs fronts, i'll go all the way around. Goodyear F1 GS-D3's
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
those are soom pretty expensive tires you're going with, I personally would go with some NT-555's (street tires not drag radials) to save soem money, they are equal in performance and usually about $30 per tire cheaper (assuming you still have the 16" rims) you could go with the nt-555r DR's for the rear but you'd probably get about 10k miles out of them with normal driving and the ocassional agressive driving
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
You should win..
but watch the Mustang...I think it will start pulling on you at the end....
just my .02..Good luck
Car: 1990 vette
Transmission: ZF6
Sanjay
08-12-2015 03:41 PM
