me vs SVT Focus
1 Post
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
me vs SVT Focus
My buddy in an SVT Ford Focus (don't know the year) thinks his car is faster than my GTA. What do you think?
Thanks!
Bill
Thanks!
Bill
Car: 1992 RS
I believe you will be alright! a stock SVT focus is like mid 15s in the 1/4 mile......... u might have some trouble w/ him though lol
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
if you have trouble with an SVT focus with your car in good state of tune, i wouldn't know what to say
1 Post
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
What exactly does SVT change? Bc ive driven an auto focus and i must say it sure doesnt feel like a 15 second vehicle. My old silverado was much quicker (5.3 99 ext cab)
1 Post
I figured I'd ask for some advice.
Thanks,
Bill
Car: 88 IROC
Engine: L98 HCI
Axle/Gears: 3.27 9 bolt
The SVT focus has 170HP and wieghs well under 3000 lbs. If it is a 5 speed and he can drive he could run a low 15. If you go from a roll he could be trouble, but from a stop your torque will give you a huge jump and you should run away from him.
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Low 15's yeah Whatever!
He's not going to be trouble from a roll nor a stop, he's not going to be trouble at all! Give him 2 car lengths and you'll still spank him.
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
If you loose, take the floor cover out from underneath your gas pedal, its stoping you from pressing it down all the way
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
One of the guys at work had one. 6 speed, and i must say, its peppy, but my intake/header/exhaust toyota corolla would beat it. I'm sure my l98 would absolutely rape it.
1 Post
Yup, his is a 6 speed. I think he might have a cam for it. And a carbon fiber hood! Big horsepower gains right there.
Car: 88 IROC
Engine: L98 HCI
I still think the GTA will win, but from a roll it might be a lot closer than you think.
Car: 86 IROC, 04 Ram, 05 SRT-4, 95 CBR
Engine: LB9, 5.7 Hemi, 2.4 turbo, 600cc
Transmission: 700-R4
Axle/Gears: 26 spline 3.42's for now
if you're car can't beat it... either sell it or give up your driver's license. they are not all that fast. and comparing them to an srt-4 is just as disgraceful. the srt-4's are very low 14 sec. to very high 13 cars from the showroom floor. 1 or 2 cheap mods will get you deep into the 13's. svt focus' aren't even categorized with them. our cars with simple mods will put you there. depending on what you have done to your car, you might seriously hurt his ego. run him and smoke him!
Cams really wake up some dohc 4 bangers. You'll be surprised when you see a b-series honda or a vvti toyota flys by you and all you hear is its 9k rpm saprano exhaust note.
1 Post
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
The SVT Focus will run low 15s, 15.4-15.2. Thats only if the driver knows what he's doing with the launch, which isn't easy. My SVT Contour was like that, low 15's, but very hard to launch. The car isn't built strictly for straight line performance though, the SVT Focus, and the SVT Contour I had were all around good cars, decent power, very comfortable, and amazing handling and brakes. You'd be hard pressed to run neck and neck times with an SVT Focus on an auto-x track. Your F-body and that SVT are two different beasts.
The short answer to the question is, you'll smoke him. Especially from a dig. There top end really isn't that good either, I wouldn't be worried in my 305 car, I don't think you should worry either.
1 Post
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
If he has a cam in it and can drive , I might be worried . What do you have a 305 ? He may even tie/win . Although if you have the 350 in that nice car of yours , it's all in the launch .... if you mess that up he is gonna win .
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
i raced my buddies 5speed svt. his car looked nice in my rearview,and that was when i had 2.73 gears too
1 Post
Thanks! I just hate to hear him talk $h*t.
I think he has a 6 speed, which will have an even slower 1/4 mile i would think (time spent shifting)
Car: Camaro
Engine: lt1
Transmission: 4l60e
You should deffinately take him. I would'nt disagree with the people saying the focus can hit low 15's though. Never have I run with run or drove one but I hit a 16 flat in my old toyota mr2, 115hp with a 5 speed. Sure the extra 55hp does something.
Car: Camaro
Engine: worked 350
Transmission: automatic
Axle/Gears: 3:73
Ported polished and milled 0.0039 head, crower stage 2 cams.. FR vavle springs, Fc gears gears Volant short ram intake, OBX 4-2-1 header, MBRP exhaust, random Tech Cat, resonator FC 65mm Tb and ported Inatake, Volant Cool air intake,SCT CHIP, Steeda engine and tranny mounts, Steeda TRI AX short shift, Eibach Sport-System Plus Kit 17" exel RH5 rims with Kuhmo ecsta tires..
Thats my mod list on my 04 focus w/ a 5 spd youlll me shocked about these little cars
i'm not shocked to see good numbers when you have all them mods!!!! all that should really drop the timeslip down quite a bit. only bad thing is the kuhmo's. they're great for cornering and such, but drag, forget about it. quite a few of my friends, including myself, run kuhmos for all around everyday kind of driving or if were gonna be cruisin. but, bfg's, m/t's, and nitto's come into play for a drag race! my friend's zx5 is quick but it's stock and definitely lacks. add on to the fact that he can't drive it for **** and you really have a slow car. got any #'s on that thing?
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
naw no numbers yet maybe this summer. ive got a nice set of nittos waiting to be put on in the spring. car is set up for auto x it can out handle alot of cars out there also suprise alot of cars one was a lg4 camaro,, with exhaust intake and a big air filter the kid blew his motor trying to keep up haha now i have 1/2 his body panels
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
I took one at a light with my V6/auto Camaro.. It ran pretty good with me but I edged him out. I had alot of weight reduction tho and ported plenums.. Pretty sure you can take him.
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
yeah i bet you did, our cars are quick not fast by any means the only time you all need to be scared is when we boost them then focus'es are a whole nother monster and in ct there are a few.. but if any 1 has a lightly modded lg4 dont bother Focus > LG4 hahah
Joe
Merry christmas all
Joe
Merry christmas all
1 Post
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Tell me I won't be shocked when you got some timeslips...
1 Post
Nah, I haven't run him yet. All of a sudden he isn't interested in racing anymore. You know what that means!
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
hey i can brag about beating anything with a v8 even if it is bad excuse for a v8. i know the focus arnt fast but these cars but serve their purpose on the track and auto x events. my camaro will kick the crap outa my focus with out a doubt.
Car: Beater 66 442 clone DAILY DRIVER
Engine: stock 400
Transmission: TH-400
Axle/Gears: 12-bolt posi 2.73 14.71et
yeah he found out whats up, he probably got whooped by a civic.
I dont think a 6 speed would be slower in the 1420, i doubt he'd use all six gears, as the svt focus is a tourer not a drag racer. some of you guys talk about 5 speed svt's. i dont think they had those...
If you raced from a roll it'd be a tight race as both cars are kinda built for midrange... but i'd say that if he had to launch with you he'd have no chance.
I know our cars can take a hell of a corner, especially when you stiffen em up, but the svt focus is a track terror. With the six speed it never stops accelerating(so what if its slow above 100), and it is tops in the handling dept. period. If you have subframe connectors and some good tires (michelin pilot sport, yoko AVS etc...) I would love to see you guys race a windy road that ranged from 20-80 mph.
All i gotta say is, its hard to luanch a 4 cyl due to its lack of torque and getting it to hook. Most guys don't launch hard enough, it bogs. Some guys reline the damn thing and roast the tires. No one seems to know how to hold the revs and slip the clutch. I can run a 2.3x 60' with my 1.6 corolla, but the rest of the 1/4 takes a long *** time.
1 Post
Car: 1986 Camaro SC
I've got a vid of me launching my SVT Contour, demonstarting the proper high rpm, clutch slipping hook and go launch. I'll post up the link later, its on street fire. I could pull 2.1's with that car on a good track, and stock crappy tires.
LINK: http://videos.streetfire.net/search/...8764ab273b.htm
Not to be an ***, but a contour is a 6 cylinder with about 100 more lb ft tq than that 4 cylinder in the focus svt.
Car: 1990 LX hatch
Engine: 5.0
Transmission: t-5
Axle/Gears: stock
i owned a 2002 SVT focus with a few mods it would give "greater" cars fits. Although if your car is in a good state of tune it should beat it. I know of several svt focus in the 14s with just a cold air and exhaust though. Race from a dig and you should murder him. dont run from a roll, thats a fwd's race.
1 Post
Car: 1986 Camaro SC
I'd be happy to return you to @$$ status, the Focus SVT has 170hp/145ft-lbs of torque, an SVT Contour has 200hp and 170ft/lbs of torque, both have similar high reving, low torque profiles, and the SVT Contour is heavier. Trust me, having owned a Contour SVT, there isn't low end torque to speak of, you don't make anything below 4000rpm, and nothing great happens till about 5000rpm, thats where the fun begins, and its pulls its hardest just before you hit the redline. Check the numbers. There is nothing easy about launching either car.
#43
Car: 1983 G20 Chevy
Transmission: 4L60
Thirdgen89GTA
09-18-2015 09:52 PM
david068513
09-18-2015 10:36 AM
