1986 transam 350
1986 transam 350
yo whats up i have a 1986 pontiac transam the car has a 350 with 305ho heads performance 700r4 and 2.73 limited slip rear. how much horsepower do you think this car has and how much torque. its an automatic. it has aluminum intake and long tube headers. and what numbers do you think it would put up at the track. anybody with info would be greatly appreciated thanks.
Jon
Jon
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
There's really no way to tell, "aluminum intake" could mean alot of things, a TBI and TPI intakes are made from aluminum, dual plane? Single plane? What casting number are the 305 HO heads, what size cam do you have? All of these things are super important to know what you're going to run, with the info you've given the only range I could guess is between 16 and 13 seconds that helps you out none.
1 Post
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Exactly what intake?
Exactly what carburator?
Exactly what heads?
Exactly what cam?
Edit:
Posted at the same time lol
416s and a single plane are NOT a good match. Swap to an rpm performer from edelbrock and you'll see a good gain down low. With a near stock cam I'd guess you are putting down 200 hp at best. If you have a bigger cam you could be making more.
Exactly what heads?
Exactly what cam?
Edit:
Hotrodboba400
12-10-2019 07:07 PM
UltRoadWarrior9
09-02-2015 08:24 PM
