355 Fastest Times
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
355 Fastest Times
I just swapped in my new motor
355 Crate Engine
Comp Cam
1.6 Rockers
Stealth Ram Induction
Hooker Headers
Dyno at 425hp
484 tq
Will post pics Asap
My car is set up with 3:73 gear ratio. Hooker Exhaust, Ram Air, MSD Ignition.
What do you think I will run the the quarter mile and top speed.
I forgot to mention I have a T-5 5 Speed
355 Crate Engine
Comp Cam
1.6 Rockers
Hooker Headers
Dyno at 425hp
484 tq
Will post pics Asap
Car: 1989 IROC
Engine: LB9
Axle/Gears: 3.42 Posi
Originally Posted by mw66nova
i predict synchronizers in your lap and input shafts on the ground. that t5 will not hold up to that kinda hp. have fun!
I agree.
You should consider a TKO or a beefed T56, kelham. If you're gentle you might make it last, but your rear axle is also potential trouble if you got a 10 bolt and you stall it high on the launch. So if you do get a tranny, look at an axle too.
That being said, if your motor's already dynoed 425 hp, you should see somewheres in the 12s with a good run. Where exactly depends on your 60'.
Car: 94 Z-28
Def a 12 second slip with a decent 60ft. I would look into a G force T56 before i would swap in a T56 thats for sure. This is coming from somone that did swap in a T56 in his thirdgen. Also like already stated careful with the rear, cuz that thing will break. With a 26" tire, 3.73's and a wild guess of a 6300RPM redline you should be able to hit 130 or so in 4th gear, and about 185 or so at redline(if you got the power to do that in 5th gear).
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
355 Crate Engine
Comp Cam
1.6 Rockers
Hooker Headers
Dyno at 425hp
484 tq
Will post pics Asap
355 Crate Engine
Comp Cam
1.6 Rockers
Hooker Headers
Dyno at 425hp
484 tq
Will post pics Asap
Its at the flywheel... havent got everything hooked up yet so i cant actually dyno it in my car ... thats just gms dyno call...
The heads are GM Fast Burns and the cam is a GM Hot Cam setup with 1.6 Rockers
Car: 1991 Camaro RS
Engine: Blown 355 Small Block
Transmission: They always break!
Easy low 12s if you have perfect traction and something doesnt let go first, and with that kind of torque it will. But hell thats the best way to show em whos boss. :-) I do all the time. (Freaking rear ends)
84z96L31vortec
08-20-2017 12:16 AM
ambainb
04-25-2016 09:21 PM
