383 firebird vs 496 chevyII
1 Post
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
OK heres the situation. Friday October 7th is the last street drags for my track and I talked to a guy with a 496 chevyII about setting up a race if he has time.He is one of the main players at our street drags and can't always get all the races done.My car is an all steel full interior stock suspensioned 10.5:1 383 84 firedbird with a medium solid roller and ported brodix track 1's running a turbo 350 with 3.73's outback on a 26x9 slick.His car (from what he's told me) is a full interior 66 chevyII on a gbody frame with ladderbars.He is all steel except fiberglass hood with a mild 10:1 496 with a small solid roller and ported factory heads.Oval port I think.I think he has a th400 trans and a ford 9" with 3.70 gears and what look like 28x10.5 slicks.He does run a 350 shot to put the car on its back bumper,but will be running me on all motor.I do know approximately what he runs on motor so it will be closer than what it sounds,but what do you guys think. Can I take him, will he get me by a length or 2, or will he flat out destroy me?I'll post the results next weekend.
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
Even though you have a pretty stout car there, a 496 incher in a 66 nova is gonna be hard to keep up with, even if the motors fairly mild, he's making tons of torque and that's a very light car. Although oval port heads on a motor of that size has gotta be holding it back some.
Don't take it wrong but I think he's gonna beat ya by a few lengths, although if I knew what you run I may reconsider....
Good Luck anyway!
Good Luck anyway!
Car: 1986 IROC-Z
Engine: 355 ci TPI, 10:1 cr, Isky cam, ported heads, dual exhaust
Transmission: 700R4, ratchetting shifter, 3.23 rear
I have no doubt your car is QUICK with that torquey 383 in it. You probably win almost all street races that you encounter. However, you've got to understand what you're up against. That big block will be tough!
I've got a 465 cubic inch Pontiac in my '68 Firebird and even with highway gears, it's a deep 13-second car, uncorrected at high altitude. The torque is just phenomenal. You bury the throttle and the scenery to the sides flies by at almost a scary speed. I accelerate so hard in that car.
So you'll have fun, but don't be disappointed if he out-pulls you.
Good luck though. Please report back and tell us how it went.
1 Post
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Yeah I really don't expect to win,but I'm hoping to put up a good fight and not loose by more than a length or 2.Last time I did get a rematch against a 468 66 Malibu that I lost to earlier in the year because of a broken distributor gear and took him pretty convincingly.
1 Post
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Well the race didn't happen with the chevyII. The turn out for the event was crazy and my car had starting problems so I only made one pass. It was against a head and cammed 5.0.The track was cold and I spun off the line and shifted early on the 1-2 shift.I still smoked him by several carlengths.It was a decently quick 5.0 as he came up after the race and told me he had run a 12.4.Even tho my pass could have been better I still managed an 11.40 @ 120.6 MPH
1 Post
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Originally posted by carlover01
he DEFINENTLY puts that car on the bumper
1 Post
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Originally posted by 88 350 tpi formula
that takes some work to get a bb in a chevy II right?(assuming since you said oval port heads) headers or manifolds? I bet that sucker flys
toronto formula
11-10-2015 06:17 AM
gixxer92
09-01-2015 04:32 PM
LT1Formula
08-20-2015 09:36 PM
