TTA vs G92 z28
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
TTA vs G92 z28
I have a 91 G92 z28 305, 3.42 gears, posi, 5 spd, no power opts the whole 9 yards.. and i know that the tta would most likley beat me stock vs stock. but how bad do you think?
just curious and thought it might be an interesting subject.
thanks
thanks
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
couple cars prob assuming both are in the same condition and drivers are the same
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Your car should run mid 14's stock, whereas the TTA should run mid 13's stock, and possibly a bit quicker with a good driver/launch. It easy to get into the 12s with one of those with a simple exhaust upgrade and a manual boost controller, which can be home-made for $10. So it may look/sound stock, but be a 12sec (or quicker!!) daily driver.
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Stock vs. stock, the TTA by a full second or 10 cars.
To get into the 12's, $30. Thrasher chip $30/shipped and paper clip Pump gas on radials. Paper clip to lock the converter at the line so when it goes into second, its locked. No turning up boost, no exhaust mods, just those mods and you'll be there.
I ran 13.0x with a chip. Didn't do the paper clip as nobody around had one but its worth .2/2mph.
Car: 1999 Z28
Transmission: A4
Car: 1997 Corvette
Less slippage I suppose, though I figured that's the point of a torque converter...to allow the engine to stay at a higher RPM while multiplying the torque until the output shaft matches input shaft speed.
Car: 1997 Corvette
I did a 8"K&N, ATR MAF pipe, cat pipe, tubular pan hard rod and lower control arms, 92 Thrasher chip and ran 12.6@110 on the Firestone Firehawks. With no other changes other than Nitto Drag Radials, 12.1@111. Drag Radials change the car emensely because you can build and hold boost to launch. My short times went from around 1.90 to mid 1.6.
So all together, those mods cost around $6-700, including tires.
As far as the paper clip, you put it in the ALDL connector. You manually lock the converter so there is no slip. Basically like a manual. On the dyno, I saw 10rwhp and 18rwtq with locking up the converter with the above mods.
The day after I ran that 12.1, I dynoed the car and it was 318/455 at the wheels
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
I didnt think torque converter clutches were strong enough to stay locked under those conditions. I would think locking it under full throttle would fry the thing.
Car: 1997 Corvette
And that's amazing that the lil V6 put out 455TQ to the wheels.. I gotta get me one of 'dem 'dere lil mighty motors
shhhhh quiet guys I have been trying to get my hands on one. I have looked at a few locally but, they are all trashed and want top dollar.
but, to the question the TTA by at least a few cars. there are even original tests that show them only running high 13's like 13.9 I think but, I would bet they had very very bad drivers to get such poor times. at the track I have seen first had 13.6 @ over 104.00 stock
you would be a mid 14.XX and still be in the high 90's mph the TTA would be pulling away pretty well
yeah, i figured it woul dbe by at least a car length in the end. im just happy my lil 305 (often flammed) will run that stock. soon ill start moddin er up..but untill then.
and i cant believe that 6 put 455 to the wheels thats amazing!!
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
I'm going with the TTA on this one...
As for the Paper clip... no ones actually explained whats the deal with it.
Where does it go? Is it a one time deal or can it be reused?
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
That's why those times in Motortrend, C&D, Road&Track, etc always suck.
1 Post
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
i know these are rare cars and all, but it seems their owners think no matter how bad the condition of the car is, theyre worth at least 10k
if i could find one thats in decent shape, for the right price, id sell my turbo Buick AND my GTA for that car in a heartbeat. TTA rules!
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
Re: TTA vs G92 z28
thanks
thanks
the TTA was the fastest Regular production 3rd gen made...the firehawks would walk them easily though
Re: Re: TTA vs G92 z28
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
I guess I lucked out, I got mine for 7K, and yeah, it has some problems. At least the interior andexterior are pretty nice, it's just needs a big tuneup.
Engine: CARBED LT4
Transmission: MK6
Re: Re: Re: TTA vs G92 z28
That's another myth. Only the 383 or whatever it was would beat the TTA. The 350 wouldn't. It ran 13.5 as well as the TTA.
go over to www.transamGTA.com/firehawk for all the info you need
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Box stock 1989 Turbo Trans AM with 96k on the clock will run 13.3-13.4 in the qrtr in the 103-104ish range.
Why do I know this? I own one and ran it shortly after I bought it.
The TTA was the fastest production thirdgen made. It will walk any and all TPI variants, LT1's also, I ran door to door with the LS1 crowd stock to stock.
Another thing, people who dont own them or dont have experience with them, shouldnt talk about things they dont know, and magainze tests dont count unless your a retard working at motor trend :-)
later
Jeremy
later
Jeremy
later
Jeremy
later
Jeremy
they were true I would have said hey they only run a high 13
but, if you see what I wrote It is almost perfect with your times w/ a couple tenths even the MPH is dead nuts on
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
Anyone looking for a TTA, my only advice is whether you trust the guy selling it or not. Go through the car completely right down to the compression and leakdown numbers.
My car wasn't bad, but after tearing it down you get to see just how many people should never own a tool set. Even the plastic ones from Tonka could be dangerous in the hands of an idiot.....
Car: 1984 Z28
Engine: 454
Transmission: Th400
tta vs firehawk
Get a transbrake for that TTA so you can get the boost up for the launch and a set of dragslicks. Then you will annihilate a Firehawk. The Firehawk is easier to regulate the power, so with stock tires it could be a close race, but I'd bet on the TTA.
Car: 1984 Z28
Engine: 454
Transmission: Th400
TTA
Just noticed there is a TTA for sale in the classifieds of this website. $15k, looks like a good one.
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
later
Jeremy
later
Jeremy
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Re: Re: Re: Re: TTA vs G92 z28
no your wrong...Firehawk #1 the press car was a 366in rodeck motored car..it ran consistant 13.2's....the fastest it ran was a 12.9 the firehawk didnt have a 350...they were 366inchers and 383's
3rd gen Firehawks are not even considered a production car. They didn't even come with a factory GM warranty.
They were more along the lines of a Motion or a Dana Camaro of the late 60's
Engine: CARBED LT4
Transmission: MK6
Re: Re: Re: Re: Re: TTA vs G92 z28
Hardly walking it... Owners knew how to drive it, magazine's didn't.
Car: 89 tta trans am
Engine: 3.8 L turbo
back in 89 I owned a 87 grand national. we would race at union grove. The TTA would run high twelves all day stock with tires. Made my GN look stupid. Couple of mod likea chip, adjustable wastegate and free floww exhaust they were high elevens. Your z28 has a ways to go before you line up with a TTA. especially at a track where some of those guys get real intense.
