Post Your Sleeper Tips/tricks
#201
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Originally posted by stu
Second, why would you run low boost to lure someone? An LS1 on even 6 psi is making at least 450 rwhp, and by that point, you aren't much of a sleeper. It's not like turning the boost down makes it more quiet.
If you've ever seen a rear mounted turbo kit (stupid idea if you ask me) then you'd know that there is usually not room for much of a muffler, let alone an additional resonator.
As soon as the person looks under the hood, they'll see it's an LS1 and know it's fast. There is no point in using those crap rear mounted turbo kits at that point.
The rear mounting kits are crap, and they don't use a muffler anyway. I say stick with underhood kits.
And that's why you don't let them see under the hood. Besides, if it's stock it isn't all that fast.. if it's cammed/headed then it has the same potential as any other 5.7l sbc.
#202
Originally posted by urbanhunter44
Running lower boost to sandbag someone.
Yep, crap. I always laugh at the benefits they come up with too.
"It keeps the engine bay cool."
Yeah, it also cools down the exhaust gas temperatures by the time it gets all the way back to the turbo. Have fun spooling now.
They also always try to make it sound like it's a simpler kit. Yet, never once have I seen one of those sites selling the kits mention the fact that all your piping will be three times as long (lag) and you'll have to have a sump pump to run oil back to the turbo and then up to the motor again. Lame.
#203
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
same potential as any other 15* headded all alum SBC with a windage tray, oring gaskets, great intake design, SFI.....
#204
Car: 91 Camaro Vert
Right, but like I said, 6psi on an LS1 is going to run 11's. Who are you trying to sandbag? An F-50?
#205
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
this car is a true sleeper
bet ya wouldnt think it has over 800 whp.
http://www.ls1speed.com/intmd8.cfm
but another good thing on a sleeper is keepin stuff looking factory.
like full aftermarket suspension setups... get them coated black to blend in with the underneath of the car. and drive it in the rain to get them dirty to look factory stock.
engine, keep it raw aluminum looking with black. aftermarket heads, get them fully ported but paint them black along with the engine block. stock exhaust to help hide that big cam and compression. LOL keepin stuff black and factory looking as cast metal helps hide aLOT of stuff. you can have a 434 small block looking like a 305/350 for the most part if you do it right.
also drive the car in the rain alot, and get that engine bay dirty/dusty. should help sell the old beat on look
dummy wire/setup air tubes/smog stuff to look like its still factory. that helps too.
#206
Car: 89 GTA
Engine: 350 tpi
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The best sleeper cars are ones that were never meant to be fast (or have a fast version/history). 3rd gens don't really apply here because although there were V6, LG4, LO3 and iron duke cars there were plenty of TPI, HO cars backed with two previous generations of performance. Therefore the 3rd gen isn't a good candidate for the sleep role. Since we strayed off topic a bit and there are over 200 posts now I think we should let this one rest.
#208
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Originally posted by Dan8289gta
Check this out, talk about a sleeper.
http://www.wilson27.com/wagon2/12.1.WMV
Rattling exhaust, messed up window tint, mismatched wheels...
But lets face it, most guys that are 'into car' don't really want a sleeper, they would rather have a car thats fast AND looks good.
GeneralIesrussi
09-03-2015 03:23 AM
