Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
A couple stories!
Old 11-18-2004, 08:53 PM
  #101
Supporter/Moderator
TGO - 10 Year Member
ShiftyCapone's Avatar
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by Orr89RocZ
ohhh, ok, i see now. it refers to the torque at the HP peak. i though it meant torque peak and its rpm divide by 5252 and you get peak HP
what you get is hP at that Torques peak rpm of 3200. 201hp at 3200rpms
You got it man You take the torque the engine is making at your observed HP level. This also helps calculate how much power your car really makes. Car companys won't underate torque (in most cases) but will HP. So throw out their rating and calculate the new one. That is why people get so excited about LT1's and LS1's. It is amazing how underrated those motors really are and the power curves they produce.
In defense of stu (I will dodge bullits for this) he claims he has no torque and only hp until he hits boost. Really, he does have a lot. It just arrives right when his HP does
EDIT: This why you will never see peak torque after peak HP.
Old 11-18-2004, 08:59 PM
  #102
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
they are a function of each other but how do you explain TPI making 250 hp and 350 torque while LT1 has like 275hp and 325torque or something like that. same goes with other motors. Some can make more torque that compariable motors while producing less horsepower. equation just gives you idea. but using it for 89 L98 specs, thats 330torque at 3200rpms. 230hp at 4400rpms. that equation gives 201hp. so its not entirely accurate.
and the Lt1 responds greatly to cam swap cuz the intake is designed to make power up to 6000rpms or higher. stock cam is barely any bigger than L98 cams which peak around 4500rpms-5000rpms. so put in a hot cam or bigger in a LT1 or Lt4 and you got mad power increase.
actually that equation is right
at 3200 rpms the motor is only putting out 201hp
horsepower generally goes higher as rpms rise.
also if you look at the equation and flip it around you can figure torque
tq=(hp*5252)/rpms
so at 4400rpms when the motor is putting out 230hp you have 274lbs/ft of torque
again horsepower is nothing more then a number derived from math. it has it's uses but when taken to a dyno the dyno only calculated torque and then uses mat to figure out horsepower based on that
if you are curious go to howstuffworks.com and look up horsepower
as far as the lt1 and why it makes more horsepower and just a tad less torque is because the lt1 has a much broader torque curve and makes torque higher up in the rpm range ulike the l98 which falls flat on it's face at high rpms thereby giving a higher
like if you have a car that has a perfect flat torque curve from 1000rpms-10000rpms (theory I know cause it can't happen) the torque will stay the same but horsepower will rise in proportion to rpms for no other reason then that is how the math works
Old 11-18-2004, 09:01 PM
  #103
stu
Guest
Posts: n/a
Originally posted by midnight383
Lastly, a ***** is the person, not the car.
Thank the LORD. I think you are the first to say that.
Old 11-18-2004, 09:15 PM
  #104
stu
Guest
Posts: n/a
There seems to be a lot of confusion about this equation, everyone seems to know that math is involved, but not why. Let me see if I can break it down for those who don't quite grasp the idea here.
Torque = work.
Horsepower = how fast you can do the work.
It's the difference between being able to lift a weight at all, and being able to lift that same weight in a certain amount of time. In fact, the actual quantity of what one horsepower is, is moving 550 lbs, 1 foot, in 1 second.
So, you can move 550 lbs 1 foot and have it take all day long. As long as you move the same amount of weight the same distance, you will have achieved the same amount of work; which is torque. But you'd have to move that weight 1 foot in 1 second to have achieved 1 horsepower.
Old 11-19-2004, 12:13 PM
  #105
stu
Guest
Posts: n/a
Torque = work
Horsepower = work x time.
Old 11-23-2004, 10:48 PM
  #106
Gr89RS's Avatar
Car: '02 Z06
5.0's are fugly! LOL just kidding
No, they are ugly compared to a thirdgen...they are as attractive as a honda civic..not to mention the interior room in them. i'd take my beaughtifully designed ,bigger thirdgen over a mustang, even though it is heavier- any and every day of the week!:hail:
Old 11-24-2004, 10:28 AM
  #107
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
I'll take my poorly designed, small interiored, smaller car over your LO3 (which I might add is slower than my well designed much larger Jeep)... See opinions are just that and are not valid when fighting facts!
Old 11-24-2004, 12:47 PM
  #108
nick418's Avatar
Engine: L98, Hemi 6.2
i thought you loved everything about your car?
Old 11-24-2004, 01:26 PM
  #109
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
Opinions are like @$$holes, everyones got one.
Even one for imports too but im not sharin it, though im sure youve all heard it Plus, I wouldnt wanna offend our good pal Stu, though he is light hearted about the Import hate on this board lol.
Old 11-24-2004, 03:05 PM
  #110
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
I was being sarcastic... I do love everything about my car, including the fact it has now been in a national Mustang mag!!! Theres a link in my sig too, the last line, click that!
Old 11-24-2004, 06:46 PM
  #111
Gr89RS's Avatar
Car: '02 Z06
Did i say it was fast???no, i didn't think so.
As stated i was responding to the post saying 5.0s are ugly which they are,and nowhere di i mention my thirdgen having the edge performance wise.
Old 11-25-2004, 12:08 PM
  #112
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Good, then you know that opinions mean nothing, its the solid facts we can use as comparisons...
Old 11-25-2004, 01:22 PM
  #113
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
mustangs are fairly attractive
but can you fit a 11 inch wide rim on the back with 315 series tires?
thirdgens can and with that and nice cowl hood, the look is evil!! LOL
Old 11-25-2004, 02:24 PM
  #114
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
No need, my car hooks on 245s (as shown by the 12.9 timeslips on street radials, with bolt ons )
With the right offset and no quad shocks I have seen 315s on Mustangs, on 10.5 rims. I had 275s on mine which looked good, but looks are subjective, power isnt!
Old 11-25-2004, 09:06 PM
  #115
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
yeah but can you guys 1g on the skidpad and a high 67 low 68 on the skidpad using stock street rubber
and only use 225 width tires?
Old 11-26-2004, 12:11 PM
  #116
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Hmm, I have tried that with the skinnies and no sway bar. Lets say, it isnt pretty! (No I have NEVER tried this). I am the first to say Mustangs are a joke when it comes to handeling until you do a lot of suspension mods!
Old 11-26-2004, 03:25 PM
  #117
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
you guys started going off on "yeah but cna you do this" thing so I figured I would join in
Old 11-26-2004, 03:46 PM
  #118
slim84maro's Avatar
Car: 86 Camaro
Engine: 5.7 with some mods.
Transmission: 700r4 needs shift kit
Axle/Gears: Stock.
wawawawawawa i still getting this thread in my user cp because i posted once here.
Old 11-26-2004, 05:34 PM
  #119
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Unsubscribe...
ALIENhumanoid
Members Camaros
80
04-23-2016 11:35 PM
Dragonsys
09-25-2015 03:51 PM
RedLeader289
09-23-2015 06:50 AM
Randomtask2
09-10-2015 08:37 AM
rudolphschenker
09-04-2015 02:41 AM
Quick Reply: A couple stories!
