'92 RS 305' vs. '93 stealth r/t'
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
i'm currently at 8000ft. elevation but that doesn't matter b/c we're both n/a. the stealth has a cold air intake and thats it. i have a K&N lid and filter and smog and a/c delete. i say that we'd both be pretty egual in the 1/4 mile since he is all top end and i am all low end. i was just wondering what you guys think and if anyone has any stock times for the stealth, i know my little 305 runs about 15.5s stock.
Car: 1991 camaro RS
Engine: 305 Carb
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
a stealth"r/t" is the twin turbo version of the stealth, much the same as the mitsu 3000gt vr4. its all wheel drive and makes like 320hp. but they weigh about 4000lbs.they run mid 14's. hopefully thats not the car your thinking of.
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
a stealth r/t is the base model stealth, an r/t tt is the twin turbo awd vr-4 like car. and i've driven his car and its pretty fast but he has no off the line power, first is his worse gear while first is my best gear. i saw on some website saying that a non-turbo'd stealth will run 15.6 stock. and i'm not so sure that my car runs 16s as i've heard of many running high/mid 15s and i've even heard of one stock LO3 running a 15.2. but i can't really say much seeing as i haven't been to the track yet. while i think his car is quite fast past 60 i had a toyota camry with almost the same exact engine (3.0L dohc V6) so i know what it can do. i just was hoping someone had some actual numbers instead of most or i thinks.
Car: '87 Trans Am
Engine: L98 (Corvette)
Transmission: M5
You're all wrong
Stealth - Base - SOHC V6 (Weak!)
Stealth - ES - DOHC V6 (Better than the first, but still weak)
Stealth - R/T - DOHC V6 (Just like the ES)
Stealth - R/T Twin Turbo (They can get up and go)
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
i'm not sure but i believe its an ES model, i always thought there was just the base and then R/T TT model. thankx for the correction!
Guest
Posts: n/a
Yeah about there. I think Bandimere is 5,680 or something like that. I'll have to double check. www.bandimere.com
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
8000ft in massachusetts? I think you mean 800. An LO3 would never run 15.5 stock at that elevation. I don't even think there are any roads that high in the US.
Guest
Posts: n/a
And you guys say that I don't bring anything to the board. I guess you learn something new everyday.
http://www.torelli.com/kom/us/default.asp
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by stu
The highest paved highway in the US is in Leadville, Colorado I think, I don't know exactly how high it is though. And there are for sure paved roads higher than that in the US. I think the base of Winter Park Ski resort is 10,000ft.
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
i live in massachusetts but i am currently in laramie wyoming for school. i was just wondering if anyone had actual times at sealevel i'd be appreciative. my theory is that i could take this stealth in the 1/8 mile but he'd have me in the 1/4 by just a little. he says he can take me in either and i just was looking to prove him otherwise.
Car: 2001 Formula
Engine: LS2
If it is the r/t model with the dohc then it has 222 hp and 217 tq. You should take him off the line considering that they are fwd. Depending if he is manual he should run mid 15s and slower if he is auto.
It should be how you described it of taking him off the line and him catching up and beating you. Although I don't think it will be too close as he has about a 50 hp advantage. Good luck either way.
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
50 extra HP doesn't mean very much to me if it takes him six hours to get to his peak power rance. its an auto so i think it would be a damn close race. the only way to find out would be to find a track but they're all close for the season right now....
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Youd get killed...MOPAR style . But like the others said, there is no way a stock LO3 will come close to mid-15's. Mid 16's, maybe...especially with an auto and 2.73 gears.
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
bleh, i was just listening to other people say that most stock LO3s run mid to high 15s. but who knows until i actually get it down to the track.
Car: 1991 camaro RS
Engine: 305 Carb
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Just race him and find out
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
i really would but we both have some points issues with our licenses, maybe i should just wait till i do a few mods and get him to go down to the nearest track with me.
Ah. I see, I have a suspended lic. for 4.5 more months. It really is no fun.
The track is a good idea.
