Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Got a race set up for when I get my engine finished
Old 09-14-2004, 01:58 AM
  #101
anondude13's Avatar
_
Old 09-14-2004, 02:00 AM
  #102
1981z28's Avatar
well
at least u all now know what my motor does i i was not full of ****.
well 450 and 500 where a little high wishful thinking .sorry
Old 09-14-2004, 07:52 PM
  #103
laiky's Avatar
has anyone noticed that those numbers seem to be from a chassis dyno?? 430 rear wheel HP? Thats over 500 at the crank!
that familiar smell again.
Old 09-14-2004, 08:25 PM
  #104
ljnowell's Avatar
Of course it is BS. Just like all of the crap in his signature. Double pumper edelbrocks, close chamber 882's, and of course 11:1 flattops (pretty good w/76cc heads).
Old 09-14-2004, 08:27 PM
  #105
1981z28's Avatar
hehehehehehe
Old 09-14-2004, 08:28 PM
  #106
anondude13's Avatar
Re: no
_
Old 09-14-2004, 08:34 PM
  #107
1981z28's Avatar
i
kind of made that guy up so u guys would beleve me.
i would like to end the war to thats y i had it dymoed but i still get **** what will it take???
Old 09-14-2004, 08:38 PM
  #108
ljnowell's Avatar
No one is ever gonna believe you because of the lies you have. I like you new signature. Good thing you got rid of the made up stuff. Well, except for the close chamber 882's.
Old 09-14-2004, 08:39 PM
  #109
1981z28's Avatar
WHAT
CUSTOM CUSTOM DO U NOT GET THAT THATS ALSO THE REASON THEY CAN MAKE 400+ I HAD THEM DONE AT MIKES SPEED SHOP $750 OF WORK DOWN TO THEM THATS Y THEY ARE SO GOOD
Old 09-14-2004, 08:40 PM
  #110
1981z28's Avatar
well
thats what i have and thats what it makes if u dont beleve it say so and move on.
Old 09-14-2004, 08:49 PM
  #111
ljnowell's Avatar
Im saying it loud and clear, but I dont need to move on. It doesnt make that crap, and you know it. what happened to the double pumper edelbrock, did you sell it for some 13:1 dished pistons?
Old 09-14-2004, 08:51 PM
  #112
1981z28's Avatar
SURE DID
O YEA
Old 09-14-2004, 08:55 PM
  #113
1981z28's Avatar
O ****
IM SORRY NOT CLOSE CHAMBER HEADS CLOSED CHAMBER NO DAM WONDER U WHERE GIVEING **** MY BAD DUDE.
Old 09-14-2004, 08:59 PM
  #114
anondude13's Avatar
_
Old 09-14-2004, 09:01 PM
  #115
1981z28's Avatar
WAHT
WE ENDED THE WAR PEACE ITS OVER I GIVE UP CAN WE JUST END IT.:hail:
Old 09-14-2004, 09:06 PM
  #116
1981z28's Avatar
THE TRUTH
9.2.1s flat tops . the heads are 882 close chamber heads highly modded . and it is my dyno sheet but i hade help building the motor it was my friend who was teacher\pal who helps me about cars ok. i didnt want to look like a full thanks u made that impossible im still learning i did not build the 430hp motor my friend steve did. i know alot but not everything . i hope we can start on a new foot know .
the factory version of my power pack heads
Large triangle over rectangle (“crown”) 882 Large chamber (76cc), hardened exhaust valve seats, compromised intake port(‘71-’76 350/400cid), best of lightweight heads
Old 09-14-2004, 11:14 PM
  #117
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Damn I wasted alot of money on my brodix heads. I should have just used some 882s
  #118
laiky's Avatar
get rid of the flow-masters cats, the alluminum rods and the pro flow breather thing you made up and then i'll think about it.
supposing you are telling the truth now, the damage has been done. I don't spend tim eon this board asking and answering questions so some trash talking schmuck can BS me. For the most part you either keep it to your self if you want it to be a secret, or lay it out on the table so others can learn from your experience and help with your problems. This board is for SHARING information.
Old 09-14-2004, 11:25 PM
  #119
1981z28's Avatar
what
the rods came with the kit if u want a link to the website i got it off of i can give it to u. and the pro-flow breather is the filters that come with any edelbrock breather.there all called pro-flow
http://www.speedomotive.com/383%20Mighty%20Mouse.htm
this is the kit i got with some add ons. there is a better kit this ones base is only $549.00
Old 09-14-2004, 11:37 PM
  #120
laiky's Avatar
alluminum rods don't seem to be an option. Besides, you do know that they will quickly streach in a street motor and eventually let the pistons contact the heads.
Old 09-14-2004, 11:42 PM
  #121
1981z28's Avatar
here
4340 FORGED H-BEAM RODS ADD $240.00
its right at the bottem and i drive my 82 daily this is just a race car.
Old 09-15-2004, 12:03 AM
  #122
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
Originally Posted By 1981z28
the factory hp was 300 and the factory ft.lbs 380. its not hard to get more when thats what u start with i did not start with 230hp and 330ft.lbs
ok, seems he squeaked one past us...NOTHING in 1981 GM produced had 300 horsies and 380 ft. lbs of torque...hell, BIG BLOCKS were castrated below that amount...and your right, you WEREN'T starting with 230 hp and 330 tq, you were starting with about 160 or so and MAYBE 300 ft lbs...i didnt check exact numbers, didnt feel like it, but that is close...
Josh
Old 09-15-2004, 12:07 AM
  #123
1981z28's Avatar
hm
yea i used the factory motor no i used the motor out of my 1970 c10 look it up 300hp and 380ft.lbs the 1981 was only rated at 175hp and 300ft.lbs
Old 09-15-2004, 06:52 AM
  #124
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
It's amazing how many lies one person can spew. I'm up to my neck in here.
As hard as 456 hp at the crank was to believe, 431 hp at the rear wheels is impossible to beleive.
Just stop lying!
Old 09-15-2004, 07:12 AM
  #125
laiky's Avatar
4340 is a chromoly alloy, it is also steel not alluminum. Now i do not believe you have even seen these rods you keep refferring to. the difference between steel and alluminum is pretty drastic. it is unlikely that you would be able to fit alluminum rods into a stock block as a stroker, did you have to clearance the reluctor shaft? what about the lifer valley brace? please tell us what was involved in getting the rods to clear.
Old 09-15-2004, 11:00 AM
  #126
ljnowell's Avatar
Yep, I said it earlier, and its true, He read a bunch of parts catalogs and magazines and put it all in his sig. What a weenie
Old 09-15-2004, 05:15 PM
  #127
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
:werd:
Old 09-15-2004, 07:54 PM
  #128
ljnowell's Avatar
Actually, you probably did. 1971 was the year chevy went to rating engines with the accessories installed. Prior to that they were rated bare, just the engine.
Old 09-15-2004, 08:10 PM
  #129
well, right back at ya bud. you didn't say you used a 70 motor. you said your factory motor, which would be a 1981 350. or 305...or maybe even a 267. i'm gonna stop now, you are burying yourself so deep already that if everyone here threw ya a shovel (pretty much everyone already has) you would STILL not be able to dig yourself out. i think you have convinced yourself of your own lies...i refuse to get in a battle of wits with an unarmed man...
Josh
Old 09-15-2004, 08:39 PM
  #130
well, i wanna see where ya got your proof from, because i have a pretty decent amount of computer skillz, and you say you have none, and i cant find ANY specs for these motors...so help me out if you are so sure of yourself...go find it and post a link...ill keep lookin...
Josh
Old 09-15-2004, 08:45 PM
  #131
ljnowell's Avatar
specs for what, the 1970 engine that the poser claims he has? The link for that stuff is
http://www.edmunds.com/reviews/gener...9/article.html
However, when you change pistons, rods, crank, heads, cam, intake, it doesnt matter whether it came out of a boat or a car, its a 350 block. But you cant tell people like him that. They are the ones that start threads like "got my new vette motor" and crap like that.
Old 09-15-2004, 08:48 PM
  #132
i know it doesnt matter in the end, but i am just uncovering one more lie...the factory "specs" he spouts off...and that link DOESNT show HP and TQ ratings...i think i might have busted this lie already...ya cant FIND THE SPECS
Josh
Old 09-15-2004, 10:36 PM
  #133
ljnowell's Avatar
the factory HP specs are listed, but not the TQ.
Old 09-15-2004, 11:09 PM
  #134
trans_am_ta_84's Avatar
Car: 89 trans am
Engine: 355
well i'd just like to say one thing.. my friend's uncle built a 383 stroker and put it in a 58 morris minor and it was pushing almost 550hp at the wheel. he owned his own shop and didmotors and trannys so i know he knows what he is doing so whoever said you can't get over 500 with a 383.. well i've seen it. and no he didn't have a blower or nitrous. actually he had a blower but he didn't put it on he said he wanted a fast n/a car.. and thats what he built.
Old 09-15-2004, 11:25 PM
  #135
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Wow lost respect for a member on here!
Old 09-15-2004, 11:27 PM
  #136
ljnowell's Avatar
No one said you cant get that kind of HP out of a 383. Not once, ever. I dotn know where the hell you got that from. This guy is spewing all over the board, making up parts that dont exist to listing parts that are incompatible and wont work. Its ridiculous to say you cant get that kind of HP. My brother, thegeneral, had a 350 that was pushing 500. It isnt that hard, just expensive. No one is saying it cant be done, we are all just saying that this guy isnt doing it. If you cant read these posts and realize that, then you should hang out with him.
Old 09-15-2004, 11:29 PM
  #137
ljnowell's Avatar
BTW, next time read the post before assuming someone else's ignorance. All it does is prove your own.
Old 09-15-2004, 11:49 PM
  #138
Car: 89 trans am
Engine: 355
actually look in the begining and you will see that somebody said you can't get 500 out of an n/a 383. don't get smart with me because i know what i'm talking about go look it's in begining somewhere. good day
Old 09-15-2004, 11:53 PM
  #139
ljnowell's Avatar
yeah, dont get smart with you, you know what you're talking about right? Cause your uncles brothers cousin told you? Troll.
Old 09-15-2004, 11:56 PM
  #140
ljnowell's Avatar
BTW, genius, show me where it was said that you cant get 500hp NA from a 383. Just quote it here so we can see it. I have read the whole thing over, and no one said that. We said he wont get it out of the combo he is planning. The only statements about turbo or SC was along the lines of:
did I miss a turbo or something? No way that combo makes that!
no where does anyone say anything about a 383 not making it. Crawl back under the rock from which you came with your "heavily modded tbi"
Old 09-16-2004, 12:37 AM
  #141
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Re: well
Originally posted by 1981z28
i going to look for my dyno slip and when i find it all of u will have ur foot put in ur mouth
first off the dyno sheet can't be correct
hp is based off of torque
the formula for finding hp off of torque is
hp = (torque x rpm)/5252
so the forumla for finding torque off of horsepower is this
torque = (hp x 5252)/rpm
so your original numbers had to of been incorrect
as was stated by someone else it would put your torque based upon the hp way above what you claimed the peak torque was
but then again I noticed the edit
from this Originally posted by 1981z28
no its not
"dyno 456hp@3500rpms 494ft.lbs2900 rpms
these are the dyno numbers 450 500 just sounds better. "
to this
"no its not
dyno 456hp@5200rpms 494ft.lbs4200 rpms
sounds fishy when you have to update right when someone proves your numbers wrong at least with the rpms you had listed
now as far as a mistype?
the keyboard is not setup to where 52 and 35 can be typoed
even more so going from 29 to a 42 to type those woudl be hard to do
so that right there is flag number one
now you say 882's are good heads
http://www.chevytalk.com/tech/engine/SBC_Heads.html
that link right there says this about them
"882" – 333882. These heads were found on early-late 70's 350 and 400 engines. They had 76CC combustion chambers, 1.94/13.50" valves, DO have accessory holes, intake port volume is 160CC's, exhaust port volume is 60CC's. These heads are made of thinner castings and are prone to cracking as well. The exhaust port on these heads is rather weak in my humble opinion, and is not considered to be a good performance head. I have read some flow numbers on the internet regarding the 882's, and I have a hard time believing some of the flow numbers people are posting on these particular castings. I did extensive flow testing on several of these particular castings, and was not very impressed with their flow characteristics. The 441 or 487 are a much better large chamber head (in my humble opinion). The 882 intake port is very close to that of the 624, the exhaust side is where the 882 is weaker.
basicly they come with HUGe combustion chambers making it hard to get high compression out of them (there goes your 11:1 unless you are running big domed pistons
they claim the casting is thinner and weaker which means not much room for porting
their intake volume and exhuast volume isn't that much which prolly limits flow
and the time they came out?
early late 70's?
those really are not the per formance days.those are the smog hurts everything days
third thing
you went and had your car dynoed at a friends dyno and came up with
went and dynoed my car at my freinds shop.
456hp@4200rpms and 431ft.lbs@5200rpms
first off your torque dropped down almost what? 60lbs/ft?
second your nubmers can't be right
456hp@4200 puts you at 570lbs/ft of torque at 4200rpms which beats your claimed 431lbs/ft
please if you wanna make something up make it a little easier to believe
there is an attach file when you try to post a msg
Old 09-16-2004, 12:43 AM
  #142
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Originally posted by stu
Oh man, I didn't even see that.
as I see the picture of this dyno the 456hp
that woudl be what? about half way between 400 and 500?
for the hp line it doesn't even go half way
as far as the torque curve i tis listed as 431 but yet it goes well above 1/4 way between 400 and 500 making it seem more like 475 or so
I would say someoen photoshopped this dynograph
Old 09-16-2004, 12:46 AM
  #143
ljnowell's Avatar
Wouldnt surprise me. Look at all of the above changes he made. Changed his signature, changed his posts everything at least 3x. There is another one too, if you follow both threads where he is talking ****. He claims to have paid 750 for the headwork, but at the beginning claims that he spent 1200.
Old 09-16-2004, 12:53 AM
  #144
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
I caught the $1200-$750 change as well, but I dont think there is much doubt left here!
  #145
ljnowell's Avatar
and my heads are highly modded $1200
And the list goes on and on. I guess the other boy genius decided he didnt want to post a reply. Good, because he is about as goofy as this guy.
Old 09-16-2004, 12:54 AM
  #146
ljnowell's Avatar
All the time, you see it all the time here. There are some guys in another thread arguing that TPI is the best thing ever. At least they arent pulling this crap out though. They are misinformed, not liars.
Old 09-16-2004, 02:17 AM
  #147
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
TPI by FAR is not the greatest thing ever.
now tuning the intake charge is a very good idea but the design that GM used more or less SUCKED!!!!!!
great for the time by compared to what they are doing with intakes now the small restrictive intake runners tuned to such a low rpm range when mated to a good healthy 350 are going to show a nice drop in power VERY quickly
great low end maybe but nothing else really
Old 09-16-2004, 12:16 PM
  #148
ljnowell's Avatar
Exactly the truth. Some people would swear it is the best thing for performa
nce.
Old 09-16-2004, 01:30 PM
  #149
anondude13's Avatar
_
Old 09-16-2004, 04:13 PM
  #150
ljnowell's Avatar
quoted from trans_am_ta_84
This genius here. I dont know where he came from, but he's probably as full of it as the other one.
Quick Reply: Got a race set up for when I get my engine finished
