Stock times
Stock times
In the 1/4 mile.....What does a stock 86 Iroc with a 305 TPI motor run with 2.73 gears and non posi....
What does an 88 L98 GTA run with 3.27 gear and posi trac...
AARON
AARON
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
a 305 would be good for mid to low 15's most likely. The L98 car would be good for anywhere from low 15's to mid 14's generally. Sometimes they can be faster.
Okay,
My '85 ran a 15.0 @ 91.5 bone stock. However an '86 will be considerably slower. It has a much smaller cam than the '85 does. Also I had 3.27 gears (BW 9bolt), and the car youre talking about has the 2.73 gears.
My guess is 16.0 @ 88
-Doug
-Doug
1 Post
Car: 99 Formula
Axle/Gears: 342
Originally posted by curt86iroc
yea, the 86 should be around 15.8-16.0. its getting no help off the line with the 2.73's and open diff.
I wanna race my 88 GTA L98 vs. an 86 LB9 Iroc, all he has is Flowmaster and wanna be cold air intake.....I wanna go for titles....so I can have a POS Iroc sittin in my carport....AARON what do you all think the outcome would be even with wheelspin
Car: 1990 IROC
Transmission: TH700-R4
A 305 tpi should be mid 15s at worst, in stock form.
