View Poll Results: who wins?
corvette wipps you BAD
19
50.00%
you loose by a little bit
31.58%
pretty even
7.89%
you win by a bit
10.53%
Voters: 38. You may not vote on this poll
early 90's corvette
early 90's corvette
How bad would one beat me in a race?
Note when my car comes out of storage it will have a new big cam in it with full new high perf. valvetrain along with fully ported intake and the heads will also be ported with bigger valves, plus what i have in my sig.
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
need more info
if he's a 90-91 vette he has an l98, and it will be closer
92 and on, he's got the lt1- you'll lose by about 2 cars or more id guess
and do you have a 5spd on your gta?, if you have the 305 auto, and 2.73 gears, you're toast
what tranny does he have?
well, hes getting that type of car so i am not sure what he'll end up with. yes i do have a 305 auto. i am getting a shift kit also over the winter and the cars has had the gears changed to 3.27's. that should help?
so how much does a corvette weigh? i am pretty sure that when i get my cam and stuf in i should have more hp, if he has the L98 anyway.
I guess you people voting pretty even are thinking its a L98 auto, and someone said whipp you bad so i guess that would be for the LT1 6-speed ?
1 Post
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
dont underestimate an L98 Vette. mines an auto with the TPI motor and i ran the car 100% bone stock and came up with a 13.9 at 99mph. what does your car run? i doubt a lightly modded 305 could match those times
Re: what about....
Originally posted by no_car_yet
if i put in a high stall converter? saya 2400? would that help me keep even witha L98 auto vette?
won't do anything for you on the highway
i see that"corvette wipps you bad" seems to be a popular choice. are you people counting for it being non-ZR1, the mods i plan over the winter, and the vette being a L98 auto
1 Post
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
Not the ones I've run. I beat them almost as bad as 96-98 4.6 GT's. The 2 races I've had with the LT1's came out with me up by one length to 100 or so.
youve got quite a few mods in your sig, what does your car run? maybe that would explain why its easy to walk away from LT1 Vettes. i also noticed your from MD. have you ever raced at Cecil County Dragway in Rising Sun?
Car: Camaro
I smoked an 85 TPI Vette. Well, I shouldn't say smoked, cause his nose was on my tail, but I beat him. The old guy driving it gave me a thumbs up afterwards. It was really close, and we both hooked up well. His was an auto too, so I'm assuming 14.8-14.9 for the 85. a 1990 is supposed to run a 14.1-14.2 with a 6-speed, so I don't think a 350 IROC, much less a 305 would be able to take it on. a A4 L98 Vette is basically an IROC-Z though.
1 Post
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
you must race some really crappy drivers. on corvetteforum there are alot of LT1 autos into the low 13s 100% stock. those 4.6 GTs you are talking about run AT BEST high 14s. so theres a good second difference between that and a L98 Vette. you cant really compare the 2 cars when theyre that far apart in performance
It has run a best of 13.8. It's a consistent 13.9-14.0 car. Best MPH at 99. That's before the trans and converter, SLP headers (had Edelbrock) and Nitto DR's. By no means a street rocket, but it will hold it's own. And I usually run at Cecil. Capital is much closer and no tolls, but Cecil is much nicer.
Most TPI Vette's that I've seen run are high 14's and some even in the 15's. I've NEVER seen a LT1 Vette run low 13's stock. Most are high 13's at BEST. In fact, very few LS1's can run low 13's. I'm not saying it hasn't been done - there was just no one there to see it. Stock of course - once modded everything goes out the window.
2 months ago I watched 2 trailers pull into Capital. Out rolled a mid 90's Vette and a 91 I think (rounded tail with quad tips). I thought man, I'm gonna see a couple of quick cars. NOPE. Both were low 12 second cars. Most people in the lanes were laughing.
The most impressive Vette I've seen was a 88. Ran a 13.7@101 I think? I talked to the guy and he told me it had the better gears (couldn't tell me what ratio though ), MAF, pressure regulator, and runners. That was on Goodyear Eagle F1's.
1 Post
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
come down to Cecil this Fri, youll see a L98 run much better than a 13.7. ill be there testing out my newest mods. see my sig for my old times. like i said before, mine ran a 13.9 at 99mph 100% stock. my brother has a 91' (same motor) that ran a 14.0 also stock. you have witnessed crappy drivers. go to www.corvetteforum.com to see what experienced drag racers run in stock corvettes
I doubt I'll be able to make it Friday night. I couldn't get there until at leat 9 due to work... After the holidays were not as busy here at work and I get off earlier in the spring. We could meet up in the spring, but I'll be more than a second quicker by then I do however run around Ritchie Hwy some nights and will gladly run any C4 I come across.
I checked out the site. Some of those times are REAL hard to swallow. Some are listed quicker than Z06's. Times posted in people sig's are real hard to believe, especially when everything you see in person contradicts it. I don't think I manage to run every crappy Corvette driver. Most of the TPI's barely spin the tires! They chirp and GO. Given an even launch they're dead even with me up till I hit second and they fall back. One of the above mentioned LT1's was powerbraking, launched at half throttle or so and nailed it half way through first. He obviously practiced.
Car: Camaro
Originally posted by 1991tealRSt-topGuy
Car: Camaro
Originally posted by Marc 85Z28
170 huh? From a measly 250HP? The LS1 has over 100 more HP and better gearing, better aerodynamics and tops out a 175. 170 MPH from 250 HP
Car: 1987 Trans Am GTA
Engine: 5.7L 350 V8 TPI
Transmission: Automatic 700R4
Was that the vette that slipped and smashed a truck from behind? I think it was like on a Arizona highway or some desert? Black or Red color Vette?
Car: Camaro
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
thats sad
hmmm differences?
rack&pinion VS. gear box steering
IRS VS. solid rear
german designed 6 speed VS. T5 (need i say more)
92+ had ASR
all 86+ vettes also got ABS
thats alot MORE than an IROC...........
engines aint everything, bub
IRS VS. solid rear
92+ had ASR
Car: Camaro
C4s weigh between 3000-3200 lbs. IROCS are about 300 lbs heavier (3300-3500)
1 Post
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
doubt me if you want to. i own both and have had both cars weighed at the track. show me YOUR proof that im wrong. why dont you go to the TPI board and ask them how much the typical IROC or GTA weighs
you must be the type of person who belives everything you read in magazines, huh?
thats sad
thats sad
I know for a FACT that a stock TPI Vette will not hit 170 MPH. Not magazine data, it's called Physics. 250 HP will not push that Vette to 170 MPH - PERIOD. While I have driven TPI Vettes, I've never attempted a top speed run. I do however know a couple of C4 owners, and they would agree. An LT1 might come close, but not a TPI.
tpivette89 What's your opinion on this?
Administrator
From the Tech Data:
IROC-Z 350 5.7 Automatic Overdrive: 3,341lbs. (Unoptioned)
The Corvette will win here IMO. It does have an L98 that has slightly more power than the Camaros L98 and the car weighs less. They are usually .2-.4's faster than L98 Camaros considering both are good running cars. Even with the mods I'd say the 305 TPI isn't gonna win, but you might not lose by that much of a distance.
1 Post
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
want my .02 huh? 170mph? certainly not. LS1s top out somewhere in the low 170s. a TPI Vette will go somewhere between 150 and 160
I don't see 170 from a C4. I put that you'd win by a bit, but I think this is only the case if you do an experienced port job on the heads and intake, and choose the right cam. Despite claims of 13.9s, this, I believe, is not average. The old stock 5.0 I had ran even with them on the highway, and pulled on one. The 90-92s are overestimated IMHO. It will be very close, and I wouldn't be surprise which ever way it turned out unless the race was a blow out.
Chris
Chris
1 Post
Car: Formula
Transmission: M5
When my car was running stronger, I raced an 88-90 L98 auto Vette and beat it. I also raced a 96 LT1 auto vette and lost by a 1/2 a car length twice. I'd say both cars were stock, but the L98 had custom rims and a spoiler, so maybe he had some mods.
This makes sense because at the time, my car was running dead even with or barely beating LT1 auto Camaro and Firebirds.
88SS6SPEED
11-11-2015 07:05 AM
Z28/ZR1
10-23-2015 01:04 PM
the_hamturdler
09-30-2015 12:50 PM
