how much power/ qmile times will this setup put out
Car: Camaro
Engine: 350 SBC
Transmission: Five speed
goodwrench 350, trickflow 23* heads, crane cam 1.6 roller rockers, comp cams XE274H, holley 750VS, pertronix flame thrower distributor, TES headers, weiand stealth intake manifold, catco cat, 3inch flowmaster exhaust.
world class t-5, 3:73 precison gears, auburn posi, BFG comp ta 255/50s
1 Post
Car: 1989 Iroc Z L98
you will need more compression. the s/r gm engines have 8.5:1, so by putting 64 cc heads on it i think you will bump it up to around 9.1-9.5:1. you will want more compression that that with a decent sized cam and nice heads. i would say if you have the trick flows shaved and are at about 10:1, maybe 375 horsepower and low 13 second 1/4's, maybe faster and more power even.
Car: Camaro
Engine: 350 SBC
how much difference in power will it be from 9.6:1 (that is what a technician at trick flow said) to 10:1 compression?
Originally posted by unknown_host
and even if it is a WC t-5, you will chew it up and spit it out with that much power.
No way he's going to wreck that tranny unless he's beating it like a red headed step child.
I'd put that car mid-high 13's because driving it is going to be a trick.
1 Post
Originally posted by ATOMonkey
WHAAAA????????
WHAAAA????????
1 Post
Now now junior, don't get all excited on me. I've seen plenty of T-5s behind 350s. I've also seen them behind turbo 2.3s and pretty hefty 302s. Unless he's a powershifting-clutch dropping-slick burning-mad-man I don't think the World Class T-5 tranny is going to just scatter parts everywhere driving down the road.
Try reading every once in a while. Here you can start with this
http://moderndriveline.tripod.com/mo...line/id14.html
Ah kids, what are you gonna do?
1 Post
The "Z" spec T-5 is sometimes referred to as "World Class T-5". Most folks, associate the term "World Class" as meaning the best. The T-5z is a 93 Cobra T-5 with 2.95 first gear set and .63 over drive. It has the best of everything. Hardened gears, short throw shifter, steel front bearing retainer, and tapered output shaft bearing. Best of all it has a torque rating of 330ft/lbs. This T-5 can handle up to 450 hp if not drag raced.
Metal is metal. It says hardened gears and steel bearings. I bet your six specs out the same way. Besides there is a difference between rated and actual. A 1.5 to 2.0 factor of safety is always engineered in. As long as he runs on street tires it should not be a problem. I'd be more worried about that 100K + mile 10 bolt letting loose before the tranny.
You are right though. If you race long and hard enough on something it will break. I guess we'll just have to see what happens.
Car: Camaro
Engine: 350 SBC
i don't plan on drag racing that much. And i sure as hell know not to use slicks with the 10 bolt. As money comes i will be upgrading. Right now i just want to drive it a little wild and not have $h!t blow up on me.
Car craft did that exact same buildup ("Worst-case scenario low compression smogger 350") with the exception of the headers about a year ago. Got 415HP @6000RPM WITH ONLY 9.1 COMPRESSION! The motor had a very broad torque curve too.
Put some DR's on it and it should be good for at least a 13 flat. I'd bet on 12.6-12.7 with a decent launch.
Car: Camaro
Engine: 350 SBC
i'd defiinitley need a new rear to use drag radials. My rear will go Boom with any sort of severe launching.
Terrell351
06-13-2021 01:13 PM
Street Lethal
08-13-2015 08:28 PM
db057
08-11-2015 10:11 PM
