What causes my engine to run hot?
My engine has been running up to 240deg? It is also runing sluggish? I have a new enigine with AFR heads... it should be fast, but it seems sluggish? timming is at 6deg advanced, vacume is 16hg steady. No vacume leaks, no codes, cam was installed at TDC, good spark, firing order is correct, it runs fine, just seems sluggish? I have watched the prameters via Diacom and it seems fine, just sluggish? I have replaced both cats as well.....needless to say...I"m lost!
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Since you already covered timing, exhaust blockage and vacuum leaks...
Running too lean
Water pump not working
Thermostat not working
Radiator not large enough to cool the engine or not enough air across the rad
Transmission too hot (oil through the cooler heats up the coolent)
Electric fans not coming on early enough or not at all
Heat range of spark plugs too high
Running too lean
Location: All over China, Iowa, and San Luis Obispo, CA
1 Post
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: 5.7 TPI, LG4
Transmission: 700R4, 700R4
Axle/Gears: 3.27, 2.73
Well, do your fans turn on? Everything in place (air damn, shroud)? Check your fuel pressure (seems like a recurring issue on the boards lately). Are the radiator hoses in good shape? Inspect your plugs. Just keep snooping around, I'm sure you'll find something amuck.
theshackle
03-05-2017 06:37 PM
db057
08-11-2015 10:11 PM
