110 and my car dies out!?
I'm on the highway yesterday and I decide to get on it I get to 110 and everything drops out at first I thought I trashed the motor then I relized it must be a saftey fetus is this some sensor I can disconnect or adjust
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: 110 and my car dies out!?
where can i get more info on how to hook up an inline switch on the vss. where is the vss located? I have an 86 Iroc-Z 305 tpi. I always thought my speedo was cable driven. But I wold really love to get that limiter to dissable. Those rustangs don't have it And it sucks when they fly by cause i can't go any faster! I'm on a low budget so the in-line switch sounds like the cheapest way to go.
Engine: 360 HSR
all you need is an on off switch and some wire. it is located on the left rear of the tranny. you'll see a big round thing with two wires plugged into it. all you do is cut the positive wire and splice in the switch. you can do it at the ecm under the dash so you wouldn't need to run wires outside the car. but you'll need a wiring diagram to figure out which one to cut. i have a diagram at work. if i remember i'll look at it tomorrow. i have an '86 ta. so should be same pin location.
Car: 89 RS
Transmission: TH350
Is this car a 5 Speed or a 700R4?
On the 700R4 there will be a plug with 3 wires in it. One of these will need to be switched. Problem is I'm not for sure which one.
Try the tranny boards, or do a search.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Or maybe even try glancing over the Tech Article on this in the Tech Articles section from this site....
Engine: 360 HSR
Originally posted by addiction115
thanks....Hope to hear from you tomorow with if you can check out the diagrame. All we need to do is run a switch?...nothing else?:lala:
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
The VSS on a cable speedo car is behind the dash, Not on the tranny. The VSS is right behind the speedo on the guage cluster.
Guest
Posts: n/a
Might just need a tuneup, or something along those lines. My 86 would run around 130-135 stock. Every 86 chip I have seen (and 87's) have no limiter really, its set to 254MPH. Or maybe you arent in overdrive? That might do it too, 110 might be about right for third wound out.
can't be 3rd wound out....about 3500 rpm... sombody told me that the vss also controles the tcc. so if i put in a switch it won't lock in and i'll right off the trany. Could that be true?
I am by no means an authority on this subject but my experience with two different chips was a cut-off at 135mph with a hypertech chip in and with the stock chip a cut-off of 120mph. Just to be sure i kept on it and the same thing happened every time 135 or 120 it just cut out for a few seconds and dropped down about five mph, did it about 4 or 5 times before i finally slowed down. Anyone know for sure??
Car: 89 RS
Transmission: TH350
Hey man, I believe its the brown wire you need to put a switch on.
You are right, the Vss does control the TC lock-up, but that is not going to help you. I thought there was no speed limiter on pre 87 cars, but I'm not sure. Who knows, your car could have alot of parts that were not originaly on the car.
You see, I have a 86 IROC, but it's not computer controlled anymore. But, most of the wires are still there, so maybe I can help you out that way. I just know that I can zoom all the way up to 140 if I please.
db057
08-11-2015 10:11 PM
